RoadconeTuning
im not familiar with that brand but most stage 1 cams will sound stock once tuned... you have to run a pretty big cam to get it to chop with a 2v.
idle rpm - it's a really simple adjustment. If i'm not mistaken i remember mine being 850 or 900. Stock is like 500/550 which leaves the cam constantly almost dying depending on how drastic the cam is.
My rev limiter is set to 6500 tooI have a camera pic taken by my friend while data logging of it at 6450 - but dont know how to upload it to online from my phone.
most likely not - my peak is around 5900-6100 that i can tell from my last crappy dyno chart, but that's with ported heads. 6400 was just for datalogging so the tune would be spot on in case i ever did go that high again.wounder how if you get anything out of revving it up to 6450'ish
Stage IIs will make the 2v have a nice chop.
Don't expect it - that's stupid low for an install and a bit weird. Also, don't forget stage II's require the changing of springs.I may pass up on the set of wheels and spring for Stage II's + Install if I can really get by with less than 300 for labor.
yeah , i do , and the roaster is our neighbors , and he is a loud fella![]()
