Cms stage 1 cams Installed
idle rpm - it's a really simple adjustment. If i'm not mistaken i remember mine being 850 or 900. Stock is like 500/550 which leaves the cam constantly almost dying depending on how drastic the cam is.
My rev limiter is set to 6500 too:eek: I have a camera pic taken by my friend while data logging of it at 6450 - but dont know how to upload it to online from my phone.
mine is idling at 1k after install , the idle is working out after the car got to run around abit , a neat trick i learned turning the A/C ON drops the engine rpm by 100-150 which makes it less chobby , it almost sound stock really but the exhaust defiantly sounds louder.
wounder how if you get anything out of revving it up to 6450'ish
as for uploading from your phone , try using bluetooth to transfer the file over to your PC and then upload it to youtube :shrug:
im not familiar with that brand but most stage 1 cams will sound stock once tuned... you have to run a pretty big cam to get it to chop with a 2v.
yea i figured as much , i pulled today at work and everyone noticed the idle and people were like... what did you do to the engine , should see the grin on my face , i am not realy hating the idle , i am getting used to it and loving it :D
Don't expect it - that's stupid low for an install and a bit weird. Also, don't forget stage II's require the changing of springs.
i find it rather expensive here , my brother owns a caprice ( 4-door Ls1 powered ) and the cam + spring install was $120 with pullies and thermostats was a 2 hours job , so i thought i was getting robbed when i payed that much money for my car :D
the car dynoed 361 rwhp and some smiliar torque with only boltons through an auto :D
vid of the thing running with awfull 3.02 gears in the rearend:
http://www.youtube.com/watch?v=IyVVK8szYA4
