351w fuel rail questions..
ID89GT
1,659
18
49
Spokane Valley, WA
Ok so am still not done with this thing..
I thought I could use the 302 fuel rails. I got new fuel line ran into between them so they would work on the wider intake and all. Well when I went to put the 351 upper plenum on, the fuel pressure regulator is in the way and doesn't work. Sooooo I went to the 351 fuel rails and am now in the problem of finding out how to run the lines to the lines that go to the tank on the car. The 351 has the quick connnects back by the firewall, while the 302 is originally on the passenger side at the front of the engine.
While the stock 351w intakes will get the motor running, they will severly limit power... I hope a upgrade is in the plans?
I used the stock 302 rails, and widened the crossovers with standard high pressure fuel line.
What regulator are you using?
Where is the interference?
I think mine hit the EGR, but that was a long time ago....
jason
