Suspension Questions
I am completely new at suspension work. I've changed a few shocks in my time but that is about it. I have some questions about upgrading suspension before I start on it this winter.
How hard is it to change a k member? Are there step-by-step instructions somewhere?
What is a coil-over conversion kit?
How does an Anti Roll Bar work and is it tough to adjust?
The shocks and springs I can handle, and I can probably figure out the control arms.
Please be as detailed as you can. I really wanna learn this stuff.:hail2:
:SNSign:
The best thing for you to do is go to Maximum Motorsports website and do some research. They have extremely detailed information on every suspension product they sell.
+1 on the MM website. LOTS of good info. Really good parts, too.
Q: How hard is it to change a k member? Are there step-by-step instructions somewhere?
A: Never done it myself, but this is the bad boy that supports your engine and front suspension. A LOT of pieces have to come apart and out (including pulling the motor) to change this.
Q: What is a coil-over conversion kit?
A: Coil-over suspension is simply a setup where the coil spring surrounds the shock/strut. Stock, our Foxes do not have coil-overs. Coil-over suspensions are easier to adjust, and are supposed to perform better.
Q: How does an Anti Roll Bar work and is it tough to adjust?
A: You already have these, one in front and one in rear. They are also sometimes called torsion bars or anti sway bars, though the definition is sometimes confused with a different type of component. The stock ones are non-adjustable, but there are aftermarket pieces that are. They are essentially springs that work by twisting, not compressing. They keep your car level through turns or during drag launches.
A good place to learn about different types of suspensions and their components is actually the HowStuffWorks website. Linkage:
HowStuffWorks "How Car Suspensions Work"
YOU DON'T HAVE TO PULL THE ENGINE OR TRANS BUT YOU DO NEED A ENGINE HOIST. WITH THE BODY UP ON JACK STANDS HIGH ENOUGH TO CLEAR ALL PARTS BEING TAKEN OUT HOOK THE ENGINE HOIST UP TO THE ENGINE AND PUT SOME PRESSURE ON IT SO IT KEEPS THE ENGINE WHERE IT NEEDS TO BE , THEN START THE TEAR DOWN AND INSTALL
BY THE WAY HAVE FUN ITS A JOB.:nice:
The first place to start is to make sure you know exactly what you want out of the car.
Do you want one that can handle drag launches?
Corner carver?
Or just a more solid street car?
Your next step will depend on your answer to this question.
I want a badass car for occasional street driving, but I wanna be able to launch too.
You could probably build something that is decent at both. But if you really get into the suspension work...you almost need to choose one direction or another. Like mine is bulit for corner carving. It launches pretty good, but nothing like a drag setup would.
But I prefer to take turns really damn fast :D
