347 or 427???
"personally i would go with the 347, or better a 331"
why do you prefer 331 over 347 ???
http://forums.stangnet.com/719569-302-stroker-information.html
I think he's refering to the old problem with the 347's and the piston pin intersecting the oil ring, which is why the 331 was created. This created excessive oil consumption and reduced engine life (not a 100,000 mile engine).
With new 347 as long as you have one with a 5.315 rod and not the 5.4 inch rod, the previous issue is not a problem anymore.
I vote for the 331 or 347 and sell the 427.
Generally speaking;
Lighter = faster w/ better fuel economy.
i prefer the better rod/stroke ratio of the 331 over the 347. i do realize that the various companies have corrected the issues with the early 347 kits. the 347 is a nice combo, and fun to brag about, but i think the 331 is better overall.
Sell all the 302 stuff and get a 460. You can build a mild 460 to make 500hp + for cheap. I would but I have to keep my shock towers. Then you can save the 427 and charge admission fees for people to come see it since by the looks of things, is precious. I laugh at people who complain of "wearing out" a motor like that. How many miles do you truly put on that thing? I think it would take atleast 20 years to "wear it out". Just a thought. I live by the 99% rule.
I don't actually laugh when people talk like they're made of money when giving advice to others and then do something totally different on their own project - but I am amused by it.
Steve McQueen didn't seem to have any problems throwing his FE equipped Mustang around corners in Bullitt.
They had to do a TON of reinforcement to that car in order to make it do what you see in the movie.. and then it was scrap after the movie. It is gone. That always upset me as well as the fact that the Charger didn't need any reinforcement.
Kinda like the Dukes of Hazzard - they didn't really drive away from those car jumps, you know. :rolleyes:
347 vs 331 . . . I thought that was only an internet myth.
I know several 347s that were built in the "early days" of the common stroker package (late 90s).
If you have someone competent build it, then you are fine. Most of these problems were people that didn't check their own ring gap or install the rings right.
the 5.400" rod still makes 20-30rwhp more than a 331 and won't have an issue if you have something in-between your ears.
393W beats 427FE? I don't think so.
427W vs 428FE:
Testing 427 Windsor Vs 428 FE - Mustang & Fords Magazine
The 428 was actually a .60 over 390 or 422. FE made 505 hp, the "W" made 486.
Use a real 427.
yeah, 19 less hp in a package that weighs in at more than 100lbs less.
1. At 1.2 HP/CI, it would be a 23 HP difference if you compared the same displacement.
2. Most charts put the weight difference between an FE and a W at 85-100lbs.
3. An FE intake is huge and weighs over 75lbs. An aluminum intake weighs 24lbs. Yes aluminum W intakes also weigh less but the net savings isn't as drastic. So the true delta between the engines is closer to 50-75lbs.
4. You can stroke FEs too, so 427 is just the starting point...
I am not against 347s, but this 20-30 RWHP figure is too high in my book. If you figure a 1.25 HP/ci 347 or 433 HP for example (a healthy street/strip 347), your going to see about 17 more RWHP than a 1.25 HP/ci 331 after you figure in a 15% driveline loss...not that much, you would hardly be able to notice it.
uh oh . . . put down the calculator for a minute. :D
A large majority of 347s I have tuned/seen made 390-400rwhp. Some more, very few less. Most of the 331s I know of/tuned made 360-370rwhp. A few less, very few more.
Mathematically you could blow a ton of smoke, but from what I have seen on the dyno the 347 makes more average power (obviously) and usually makes 20-30rwhp with the same given stuff: AFR 185s/Holley Systemax/OTS hyd roller, 1.75" headers, 3" exhaust
if you look anywhere near the dollar per hp, the 393W would rape that 427. plus no horrible fitmet issue and all your stuff bolts on anyway! the only reason a 427 would be in there is for wow factor or because you have $$$$$$$. a 393 would lay down the power and kill that 427 at half the price! and reliably with no parts issue whatsoever.:flag:
They had to do a TON of reinforcement to that car in order to make it do what you see in the movie.. and then it was scrap after the movie. :
A TON? Like better springs and shocks? The roll cage was for driver safety not to stiffen the chassis. That was done to the Chargers too. Magazine articles about the movie/car(s) didn't come out until years later. Peoples recollection of what was done probably varied greatly. Yes, the car was trashed afterwards. Every body panel was dented and I am sure the subframe was twisted. It cost more to repair than the car was worth (then).
HowStuffWorks "Mustang Stars in Bullitt"
"Two identical Mustangs and two matching Chargers were used in the Bullitt chase sequence. So that the four-speed Mustang could run more easily with the brawnier four-speed 440 Magnum Charger, Hollywood engineer Max Balchowsky installed a racing cam on both Fords, milled the heads, and modified the ignition and carburetion systems. Additionally, Balchowsky bulked up the suspensions of all four cars for improved strength, handling, and control. One Mustang and one Charger were fitted with a full roll cage."
Go drive a 2008 Mustang with a V6 and a V8. Are you going to walk away from the test drives going "Wow the V6 Mustang with the 100lb lighter engine handles so much better" or "The HP and Tq from the V8 was awesome."
Well, that's another version of what happened. The version I read was that only the Mustang doing the jumps needed reinforcement of the front suspension and not the Charger. It was many years ago when I read about it. I have no idea which version is correct. The details in the story you quoted make it seem possible that it's the correct version.
I would actually say both - at least where my convertible is concerned I like the power of the V8, but it handles comparatively crappy with more weight in the front. I still would want a V8, but not a big block. I'd rather do a strong small block for a more well-balanced package. I love not having to slow down for corners and cloverleafs.
