Help! Question about strut tower mount & Eibach dampers
MustangLX-5.0
856
Lehigh Acres Fla.
This being on my 92.I installed the Eibach pro kit springs & dampers on the front end quite awhile back.The car is far from driveable.I used stock strut tower mounts & bushings with the dampers.I heard from a few of you back then that it would work fine.
Well something doesn't work.That nut on the center of the strut clamshell doesn't screw down that far.So being that the threads dont stick out the top part of the nut.It hits the spacer that fits inside the bushing after a few turns.Am I making any sence to you?
I'm also having another problem which may or may not be related to this.After installing both the springs and struts,there's a problem with the sway bar end links.I'll jack the control arm up,mount the links into the arm,then onto the sway bar.The real problem,letting the control arm down more than a quarter and it starts pulling so hard on the sway bar links.I have to stop..it WILL either shred them or bust the sway bar mounts.
So I tried this with the extra long stock end links....even with the stock sway bar...STILL THE SAME THING.Its like the control arms go down a lot more than normal.
What's going on here? I totally stopped working on this car for nearly 10 months.I just need a 100% "for sure" answer so I can finish this thing and get it back on the road.
I can't find that number anywhere. Did you look at the top of the shaft where the threads are and make sure there wasn't a sleeve or somthing there? All I can say is call Eibach. They should be able to resolve this over the phone pretty easily.
Couldn't find that number myself.I just found the install sheet.Here's the info listed.
Pro-Damper Kit - #3514.840
Ford, Mustang - V-8, V-6, I-4, 1979-2002 (Except SVO, Cobra and Cobra "R")
Front Damper 3514.8001
Rear Damper 3514.8002
The rest is just bushings,washers and bumpstops etc.
Maybe someone can make sense of all this.It appears to be the correct kit.The only "sleeve" that's installed is the one on the very top of the strut rod at the strut tower.This is a spacer that goes to the factory mounts so the nut has something to tighten against.
The kit comes with 2 upper strut spacers and 4 lower mount spacers.The lower ones are thin pieces of metal.The uppers...I guess are these 2 sleeves or (spacers).They are the same diameter as the factory ones only 1/4 the length.
The kit only says to use these upper spacers if needed.It doesn't say where they actually go.
I don't know if your familiar with Eibach damper kits or upper strut mounts.I will list the assembly of an upper mount just for verification purposes.
Strut rod passes through strut tower - Bump stop fits on rod first - Then lower clamshell body of strut mount is placed on next - "sleeve" is next inserted (about 2" long) - Insert bushing (has hole in center of bushing so it fits into sleeve and fits lower mount clamshel half) - Upper clamshell with hole is inserted on top (this sits over bushing and sleve) - Nut inserted onto rod and tightened against clamshell (have to clamp rod with vice to prevent from turning).
The upper clamshell must meet against the sleeve to tighten the whole assembly properly.The sleeve is the same exact length as the bushing.Using the Eibach sleeve or none at all would allow the bushing freeplay and wobble.
I've been doing every bit of work to this car.I have no outside help except for SN.
I seriously appreciate your help this far.
