Drag strip ratio (4.10, 3.73?)
Touring23
294
Washington
This is for a fully-laden street Cobra with 26.0" tires, 5-speed, and mild mods but no blower or nitrous. If I did the calculations correctly, trapping 100mph would result in either 4800 (3.73) or 5300RPM (4.10) in 4th gear.
3.73 is all ready installed and am curious about going to the 4.10?
Thanks. Searchy no findy. :popcorn:
lol since this is bothering you so bad and you already have the 3.73s in why don't you take your car to the track the next time you get (depending on if the track is still open near you) run your car and then change the gears to 4.10s and run it again. TADA!!!!!!!!!!! There will be your answer!!!!! :hail2:
However I would focus on other mods. Port your intake, get better heads, etc etc.
You're definately looking at it the right way. You should be gearing the car to top out in 4th gear at the end of the track. Honestly, I would go with the 4.10s. They aren't that bad on the street, and the car should go faster.
Kurt
