I put new tires on the rear of my 86 GT and I noticed the drivers side quad shock bushing is shot on both ends. I've posted before about a vibration once in a while in the back that sounds like you are running on rumble strips...happens at different times, different speeds. Would the bushing cause my problem?
I know that some people take them off, but everything is stock and I'm not comfortable taking them off. I assume if I'd put a GOOD set (KYB's?) of shocks on the back I could remove them? Otherwise, should I just get new bushings? I just need to fix it as low cost as possible as the car needs other things just to keep it on the road.
Thanks.
Thanks.
