Quad shocks causing vibration?
I put new tires on the rear of my 86 GT and I noticed the drivers side quad shock bushing is shot on both ends. I've posted before about a vibration once in a while in the back that sounds like you are running on rumble strips...happens at different times, different speeds. Would the bushing cause my problem?
I know that some people take them off, but everything is stock and I'm not comfortable taking them off. I assume if I'd put a GOOD set (KYB's?) of shocks on the back I could remove them? Otherwise, should I just get new bushings? I just need to fix it as low cost as possible as the car needs other things just to keep it on the road.
Thanks.
New tires? Sometimes the raised letters on the back of my tires rubs the tailpipe on curves at speed.
You can get new quads at Autozone they're listed under "steering damper".
No, it's not the tires. It's been doing this vibration thing for a long time. It had two different vibrations...one like I described, and then the whole car shaking at higher speeds. The new tires fixed the whole car shaking problem because the old tires were all dry rotted, hard, and had high spots.
I was just wondering if the bushing in the quad could be causing the vibration. I am going to replace them anyway...but just curious.
Auto Zone lists rear end quad shocks as steering dampers? Strange.
I don't recall that there are bushings on the quads :scratch:
Been a while tho. The quads are simply there to keep wheel hop down. My personal experience is that they don't cause problems. Brakes in good shape? Bearings?
Yep bushings are on the quads, and mine have seen better days. lol
The driveshaft is a common cause of vibration, it's one of the main reasons people go to aluminum.
Still have the dog bone on the axle? It's supposed to dampen axle vibrations, but been debated whether it does anything or not. :shrug:
Instead of the bushings being the cause of the vibration, maybe they are the result??
I'd guess bad wheel bearing on that side of the car
Yea, I thought about that too. But it only does it once in a while. I was thinking the bushings because maybe they get bound up once in a while or something causing the rear to be off a little. Unlikely, but who knows. I just need to take a day, replace those things, and check the UCA and LCA bushings and the bearings and get it figured out once and for all.
I've had the driving on rumble strips thing happen to me.
And it was in fact the driveshaft/u joints.
Not sure which one, i bought a FMS driveshaft.
