What to Keep, Move, or Delete... ENGINE BAY QUESTIONS!
Adam95GT
2,564
Burlington, NJ
Ok well if anyone is following my engine bay clean up thread i need to figure out some things...
What can i get rid of... Where have you moved things....(CCRM, FUSE BOX)
Can i get rid of the ABS...
What about the smog...(will i be able to pass emissions in NJ)
The AC is getting tossed...
Pics would be nice guys!
Also wanted to know if anyone had an extra harness or pieces sitting around... it would help with my wire tuck.
Thanks,
adam
i moved my CCRM to the passenger fender and removed the smog and EGR as well as the charcoal canister.
thought this was a really neat install....
Fair enough, sorry for the joke.
If you don't drive the car in the winter, you can dump the heater core and heater lines.
ABS should be able to be removed, but you'll get a light I'm sure. You will probably have to run new brake lines in the process though, just fyi.
If you're going for ultimate weight removal, you could toss the brake booster and get a manual M/C too.
Are you doing this for better times at the track or just to look 'cleaner' under the hood?
Scott
Scott
Cleaner look under the hood. ABS is already going we are going to make custom lines... we have to pull the dash to replace the heater core mine is bad. so we are taking the whole abs system out... so no lites there... Im gonna keep the heater cause the AC is going and i need atleast one way to defrost.
you can convert your washer fluid tank into a coolant overflow tank and then remove the stock one. of course that means now washer fluid.
basically your already removing all the stuff you can. your next thing is to replace with lighter stuff like aluminum/carbon fiber parts.
The aluminum heads and tubular k should shed some weight... im getting rid of the washer fluid tank already... but since it is smaller i might keep it for a coolant overflow mounted in the inner fender
A+ thanks for that idea man.... do you really need an overflow...:shrug: i mean if the pressure gets too high i need somewhere for the coolant to go... but how much room is really needed... Does anyone know normal temp b4 expansion IIRC the T stat opens at 180.... and if i knew how much coolant is need in the system i could calculate the thermal expansion of the water.... Thus giving me the amount of increased volume. and make an appropriate sized overflow for the job...
I have limited knowledge about the heating and AC systems so can anyone tell me if I can either bypass or remove the heater core and still be able to use the AC? It doesn't get cold enough here to use the heater but I definitely need the AC from April to October.
I'd like to remove some weight and clean up the engine bay by removing the heater lines.
Dude, you scare me. :hail2:
If I had to do that much math to make a part for my car, I'd drive an Accord. At least I think that's math... If it's any help at all, your "6's" are backwards.:shrug:
I agree...I had to do crap like that in my engineering classes:eek: I suck at math and couldn't ever relate it to cars, so I'm not an engineering major any more.
If you're not gonna drive it in the rain, you could delete all the windsheild wiper stuff and just put Rain-x on the windshield for the occasional unexpected downpour.
thats only minor physics/chemistry. im a chem major. :nice:
wow. I want to do mine like that when I get around to putting the 514 in. Here in PA if you remove the emissions stuff (smog pump and all that) you will fail. Not sure how it is in NJ but just a thought for ya.
A lot of guys put their fuse boxes in the fender. If you ever need to change a fuse though you gotta take your wheel off and remove the plastic wheel well thing. Sounds like a total pain in the ass
I am also in the process of doing the same thing. If you cut a hole in the drivers side apron you can fit the fuse box and wiring through and mount it in the inner fender. I found a site called MustangAddiction.com. he shows some ways of cleaning up the egine bay and smoothing everything out under the hood. there are some good pics there I reccommend you check it out first.
Also I heard you have to extend the passanger head light wiring after you relocte the wiring to the fender. As for the wiring that is on top of the rad apparently can go underneath the rad.
I have also seen guys use windshield washer hose with a slit down the middle to go around the sharp edges of the holes you cut in you apron
The ccrm can be moved to the inner fender aswell
If I think of anything else I will let you know.
