what bogarts?
autumn_again
356
Hamilton, NJ
tomorrow morning i'm ordering bogart 15x10 rears.
i was gunna just get the 15x8 jegs, but for tire options i like the 10 inch alot better.
and i planned on going forced induction down the road, so i have more tire options then too.
i'm inbetween
D-10s
bolted R/Ts
welded R/Ts.
here are my fronts.
i'm leaning towards the R/T series preferably the bolted, but i love the d-10s, just not sure mix and match.
ordered the bolted r/ts, with 325/50/15 mickey thompsons street radial. its a big tire, but i am not going to drop the pressure that much at the track, and i figure i need to heat the tires less.
the mickey thompsons are expected 2/4. the bogarts they said about 4 days.
hell yeah. i was gunna go d10s incase i ever go bogart skinnies, but eff it. i'm young. i'm sure on one car i'll own in my life i'll have a set on there.
i was gunna go M&H, but from what i've read their tires run skinny.
and the one thing i missed from my old car was the big fat tire out back. a 315. now i'm running an even bigger tire, so that should satisfy me hah.
For track only wheels, I wouldn't mix and match. My MTs took quite a bit of burning out to heat up properly. Granted mine is the auto with stock converter so the RPMs were dropping faster than I wanted/needed them to. I'd say it was about four burnouts before the tires were sticky to the touch after a pass. I like the RTs.
i'll be using them street and strip.
i've heard alot of the bogarts in the front are bending, cracking etc. but no problems with the rears.
the roads around here arent too bad either. i know where to avoid haha.
if i was gunna go with just track only wheels i probably would of just went with a slick on a 15x8.
do you have a line lock on your car kool?
i am hoping i am still able to heat the tires starting in second with these big meaty things. i have no problem turning the 235/55/17s into melted rubber in second.
from what i've read i will probably get a year out of these tires. which is fine to me for a good tire.
i was suprised when he told me about 4 days till the wheels are finished. i am unsure on lug nuts though. he says that hes not sure if they come with them, and everything i've read they do. i need to order the sway bar relocation tonight.
everything i've read on bogarts is like 2 weeks wait. but everytime i've talked to stage3 they've told me 4 days.
and the mickey thompsons are on backorder, but now on my summit order it says friday instead of wens the 4th. so thats even better.
Autumn, do you have stock studs? If so are they going to work with the new Bogarts? If so I am going to try to sneak a set of Bogarts all the way around this year before my kid is born, lol. Let me know if you dont mind and be sure to post pics as we have the same color car I'd like to see the r/t mounted.
Bob
I don't have line locks on my car.
I've heard that Bogarts are not recommended for street driving. I imagine it is because they are only designed for straight line and not able to handle much cornering load.
yeah. so far i've only seen issues with the fronts though. so i'm just running the rear bogarts.
i just gotta be cautious. and black gt460. no problem i'll post pictures as soon as i get them. from what i've read, the roush bogarts that youcan get on ebay for like 699 a pair, need longer studs because of how they are designed with the spacer welded to them. all the other bogarts are designed differently where you can use the stock studs. you want lugs like these.
you need the rear sway bar relocation bracket also. about 38 bucks. i am going to order that for now because i need subframe connectors, but eventually get the xtreme anti roll bar when i have the cash.
Autumn, I found 15x8 bogarts w/5.5 backspace for 405 ea. I know most people are unaccepting of the 15x8 compared to 15x10 but for someone like me with a mild car with no huge plans any time soon and no workspace to do the sway bar relocation kit it is a direct bolt on for me. I think I could grab those with some 275/60 MT's and be good to go, you think?
i'd say go with the 15x8 jegs. like 120 a piece. direct bolt on. think its 5.5 backspacing.
275/60 is a 28 inch tall tire. so if you dont have any big big plans you could probably get away with a 275/50.
Bolt On Performance Parts For Your S197 Mustang - Muscle Mustangs & Fast Fords Magazine they used a 26 inch tall tire here and from what i remember reading they didn't have any problems.
Yea your right a 50 would be better. The only thing about the Jegs wheels are I think the center caps look a little funny...is that me or did I just see some bad angles, they look a little big and stick out far.
yeah they arent the prettiest. i'm actually taking my jegs center caps off. i don't want a nice bogart center cap in the rear and then 89$ jegs logos up front haha.
when i get the bogarts i'm gunna try the bogart center cap in my jegs. if they fit, theres the solution. hah.
the 50 will be a little shorter then the stock wheel, but it'll hook a million times better.
got my lugnuts and my sway bar relocation bracket today. wheels i am going to call stage 3 today about them to see whats going on with them, and the tires they are expecting 2/3 i believe at summit
which kinda sucks because they said expecting today. but oh well.
so i got home from my first day of work at my new job, and log on to see if summit has replied to my email. they told me mickey thompson is really screwy with the estimated dates for their tires. so i sent an email back tonight after thinking about it, and asked if they could send me the nittos in that size.
they are the same price, same size, a little more streetable, and last longer. i shall get a message back from them tomorrow hopefully. but i don't see any problem with them substituting for it, since under the mickey thompsons it says substitute for = and it lists the nitto 555rs in 325/50/15.
i plan on calling stage 3 tomorrow when i get home from work, since i get home around 5 eastern time which is about 3 in their time, so they should be open. they told me about 4 days.
the way its looking i may be rollin' on bogarts this week. woo!
for now i'll just play with my lugnuts.
