TFS 4.6L intake opinions?
jivepepper
776
Under a Sombrero. in WV.
Trick flow Track heat ford 2v sohc intake manifold
I'm due to get my income tax return on the 13th and I think I'm going to go with the oval TB version. Last time I went to my tuners I put down 572.
My best of 598 was at a shop I usually don't go to, and it was on a slightly cooler day. Where I tune always seems to read a little bit lower than a couple other places that my friends and I have dynoed. For example my v6 turbo dynoed 431 at our tuner's and 474 on another dynojet. A 43rwhp difference.
I'm wondering if this intake can get me over 600 on my tuners dyno?
What intake are you currently using? Unless its stock, I don't think the TF intake will be that much better than what you have. If your stuck on the TF intake, the oval tb opening is the only way to go with your power level.
The only thing i would check into before you order is if it works with centri superchargers. Ive heard (not positive) that it wont play nice with vortech because Trick Flows dumb ass design requires the alternator to be flipped around and face the other way. :shrug:
I was going to get it also for my car, but didnt for that reason and ended up going with a bullitt intake.
I already have it will work. I have seen a novi 2k with one. I also called TFS.
