Can't get car Aligned!
so my mustang was in a bigger wreck than just a deer....
my drivers side front wheel is horribly out of alignment. i took it to a shop and the guy said it was already adjusted to 2.5 degrees and he couldn't fix it. my tire is showing cords so whats the fastest way to fix this problem? my brother said caster camber plates. what do you guys think....
something may be bent. caster camber plates would give you more adjustability, but if it is adjusted to a large degree and still not in spec, something may be bent. also, which measure is out? caster, camber or toe?
im going with the lca being bent slightly or the shock... pull the wheel off if you can and look around for signs of paint cracking or jus bends in general in the arms .. i see it at work all the time ... it can be fixed...
What did I do to my car to be rough on it? I drove it like I stole it, but ti was mine, a mustang, and I drove it the way I built it to be driven haha. David... IDK wtf to say about that kid :D
And yeah the damage was worse than just a deer, trust me.
a male deer can weigh 250 pounds, hitting one at highway speeds would be like hitting a brick wall...
but like previously suggested, i'd have the front suspension components on that side gone through first, then if that's not what's doing it take it to a body shop and see if the frame is tweaked, most good body shops can pull it depending on how severe the damage is... best of luck man
Chris
well i dont think a 250lb deer would cause enough damage for a new k-member to be welded in...
heres some pics.
passenger side fender-
k-member-
rocker panels-
wheel well-
Are you sure the k-member is welded up?? I can't really tell from the pics but the k-member is bolted to the car and can be removed. IS it welded to the car in your pics??
If so, i guess you gotta find a new k-member
Also, measure the distance between your shock towers. MEasure to two hard points and ask someone to do the same on their car and compare
i clearly remember when you first got your car there was a member who posted in the thread about how long he's known the previous owner and "could tell you some stories about that car"
PM him and see if he knows anything about the previous owner driving the car into the grand canyon or something :shrug: might shed some light on the situation
Yea i was thinking that same thing just havent gotten around to doing it.
795.0pacecar helped me out alot and we got the toe set but i need caster camber plates to fully fix it
