- Jan 24, 2007
- 29
- 0
- 0
I could use some help here. Let me try to lay this out as best I can.
Just finished putting on Ported E7's, Cobra Intake, 30# injectors, C&L MAF, 1.7 Rockers. Install went well I think. I fired her up today and everything seemed pretty good once I set the idle and the timing. Car idle's at 1200 and Timing was at 16*, and Fuel Pressure at 40-42 ish.
Once I went for a ride there is a noticeable issue right away, once you get on it, she bogs down real bad, and if you punch it, it will backfire.
What I did ensure was that the distributor went back correctly, where as when the harmonic is pointed at 0 (TDC) the rotor is pointed to the #1 mark on the cap. I believe that is how it should be.
I'm inclined to lower the FP a touch, but not sure if that will correct it. Perhaps the 30#'s are too much, but I plan on spraying it, and need the injectors.
Any help would be appreciated.
