2 piece poly bushings are good only for the track or straight line. They bind in corners. This is why many don't recommend to replace the uppers because of the binding.
J&M (who is a sponser on Stangnet) has a very cool 3 piece design and are cheaper than MM. The owner of J&M started MM so he know's his stuff. The lowers are like $200. For one of my cars I just bought adj lowers and also the uppers because of the bushing design it won't bind. The center "Hard" bushing is a Ball and the sides are softer and "cup" it with no binding!
Heres a link to their site. You can get the 3 piece front and rear or 3 piece front and a spherical rear which is how MM does it on their street versions. This is the one I chose.
Rear Lower Control Arms
Heres a quote from their testing.. look how the 2 piece bushings that most people use will break a 1/2" bolt with 10 degrees rotation!!
Poly-Ball Bushings:
5 degrees of total rotation = 26.1 foot/pounds of torque
7.5 degrees of total rotation = 35.8 foot/pounds of torque
10 degrees of total rotation = 41.7 foot/pounds of torque
Standard 2 piece setup using only 85 durometer bushings:
5 degrees of total rotation = 124.7 foot/pounds of torque
7.5 degrees of total rotation = 156.4 foot/pounds of torque
10 degrees of total rotation = not measurable with fixture. The 1/2" grade 8 bolt twisted in half at 9.2 degrees which was 210 foot/pounds of torque."
