bnickel
Ok, so here is a little progress. I was able to get the inner bearing I needed yesterday to mount the LTD rotor onto the Mustang spindle. The part that works is the standard drum inner wheel bearing, Timken Set6. The outer was even easier, I had the wheel bearing for it already as it was the out for the Mustang drum. Rock auto lists that as A1 for the part number, BCA/National.
So I've got the rotor mounted on the stand now. I tightened the nut down on the spindle and the rotor spins nice and freely. I'm going to try and get the fasteners I need today to bolt the brackets up to the spindle and see why they want you to drill the caliper, grind it and face the mounting ears.
I'm also going to try and find a race shop that stocks 2 piece rotors so I can try and match the drum hub with a set that has the same measurements as the LTD rotor so that we can use 1 bracket for everything.
I suppose I'll pull the splash shield off of my 67 in order to mock everything up properly. I'll provably do that next weekend.
any pics of the mockup so far? i'd like to see them if you do.
