SOLD Used 94-04 Mustang Cobra Rear Brake Calipers w/ Carrier Mounts
MoDriver
71
USA
[SOLD]
Posted is a Pair (1 driver's side, 1 passenger side), used 94-04 Mustang Cobra/Mach 1 rear brake calipers with slide mounts.
These are located in Bradenton, FL (34210). Price reduced for Stangnet members only to $100/pair/obo SOLD SOLD SOLD
This Cobra caliper is from a functioning 1998 Mustang Cobra and works with the 11.65" Cobra rotors. Great choice when doing the SN95 Cobra brake upgrade on the 79-1993 Mustang or upgrading to the thicker vented brakes on the 1994-2004 GT/V6 (when upgrading to Cobra specification brakes). This is a pair of rear calipers including mounting slide brackets and a pair of brake pads (for fit checks, verification, etc.). The mount slide brackets on these Cobra calipers provide proper clearance for the thicker Cobra Vented Rotors (Other slide mounts may not clear cobra rotors).
Note: These are real Cobra Calipers that are reinforced when compared to standard rear Mustang calipers. See the comparison image.
*For those upgrading to the Cobra style rotors from non-Cobra/Mach Mustangs you will likely need axle mounting brackets (to reposition the caliper) and the larger vented Cobra Rotors (and fresh Cobra brake pads). Do some research, I have done this with a new edge Mustang GT if you have questions.
*For those that aren't upgrading (yet) that have a Mustang GT, you can use these with standard Mustang GT brake pads (I have new ones available if needed, PN: MKD627) if you are waiting for your thicker, vented, Cobra rear rotors.
These aren't included with this listing, but I wanted to provide this information (if needed). Ford sold a kit to help adapt the use of rear Cobra vented rotors on a non-Cobra Mustang with an 8.8 rear. Ford Racing Performance Parts M-2300-M:
1 ADAPTER, CALIPER TO AXLE L.R. F4ZZ-2C101-B
1 ADAPTER, CALIPER TO AXLE R.R. F4ZZ-2C100-B
2 DUST SHIELD F4ZZ-2C028-A
6 BOLTS, DUST SHIELD N602726-S2
2 ROTOR, REAR F4ZZ-2C026-B
1 MOAN BRACE, R.R. F4ZZ-2C366-A
1 MOAN BRACE, L.R. F4ZZ-2C367-A
Images are of actual items (except for the comparison image).
Can you please post an image of all of the parts included with this sale? I do not see the brackets (mucho important for anyone doing the conversion).
Thanks,
~Noobz
The included mounting slide brackets are shown attached to the rear brake calipers along with the used Cobra brake pads as well. Anything else isn't included, but mentioned FYI.
I hope that clears things up.
Let me know what you are looking for and I can try to help further.
Reactions: Noobz347
Duh, I see it now. Thanks. :)
No worries!
Essentially, I am listing serviceable used loaded calipers from a functional 1998 Cobra Mustang. I saw an upgrade path for those wishing to do the conversion and since my calipers include the slider mount. I have heard that some people have had to grind their slider mounts to clear the thicker vented Cobra rotors, so I figured it might be helpful to have these.
Also, I happen to have some new brake pads for a non-GT for those interested in doing the conversion in stages (upgrade caliper with Cobra sliders first and then later get the axle bracket, anti-moan, rotors, etc..). Just some options.
Also, related to brakes/upgrades, have some new front Hawk HPS front Brake pads I will be posting soon. (FYI)
