Interior mounting locations for MSD box
pyroman
480
Ennis, Texas
Ok, please don't crucify me for this as I can't really find anything through searching although I'm sure there are lotsa threads on MSD box mounting.
So if everyone is cool, I'll proceed with my question.
I have a whole MSD setup ready to be installed but what is holding me up is mounting the box. I have a 67 with the deluxe interior, that's the center console and stuff. Basically, I don't really like the look of the box in the engine bay (just personal taste). Therefore I'm considering interior mounting as my primary option (barring other suggestions). Just upon first glance, there isn't much obvious room for the box to sit. I sort of like the passenger kick panel, but I'm afraid of cowl leak. I also tried fitting it in the center of the dash, behind the center console, but it's hitting the heater box on the driver's side.
I have a coupe of ideas but I don't want to start cutting up my interior until I'm 100% sure it's a good location. Anyone have some ingenious ideas?
Here's what I did in my '66.
I relocated the battery to the trunk and placed the box on the inside of the front radiator support. You can't even see it's there unless you peer over and look back at it. Maybe look into doing that. It will still be in the engine bay but will be out of sight.
Plus the benefits of moving the battery to the trunk to spread weight better help too. I'll snap a couple pics if you're interested.
-Dan
I installed my Digital 7 and MAP sensor directly under the ash tray on a thick sheet of plexiglas pop riveted into place. That way I can see the wires even whens its mounted. I dont know about fittment on a 67 but your box is smaller than mine so theres an idea to consider.
I couldnt get any desent pics of it mounted but if you want some let me know and I'll take some tonight.
-Dan
I'm considering doing that as well. A friend of mine suggested relocating the battery to the trunk and using a faux battery box to put all my electronics in. I'm not sure I want to got that far. As far relocating the battery goes, are there any "kits" to do it? What kind of cable did you run, 0 gauge?
Yea those pics would be great if you don't mind!
i made my mounting bracket from 16ga.plate 4x12.5 weld L bracket on the back plate and used an existing holes from the heater motor.
msd box and coil inside
I'm sorry, I'm not sure I'm completely understanding your post. You've made a bracket for the MSD box using L bracket steel and mounted it where the blower motor was? So you've done a heater delete? Why do you have your coil mounted inside the car?
Summit SUM-G1231-K - Summit® Premium Battery Relocation Kits - summitracing.com
This is the one I'm using. It's arriving today so I can snap some pics of the completed product if you would like.
Yea if you wouldn't mind that would be great. Did you check the corner weights of the car to see where the best location in the trunck would be or are you just putting it in the most convenient place?
Remove the glove box innards and make a plate to mount everything where the box section used to be. Use the glove box as an access cover...nice one at that. You will need to route the wires through the firewall, but it looks good, is hidden and will be out of the heat.
out of curiousity... i mounted my MSD on my shock tower, not too far from my headers etc... where it no doubt gets pretty hot. is that the reason you guys are installing it at random places in the car? and could this be a reason why my MSD may (not sure theres anything wrong with it yet) have gone bad, causing starting/timing issues?
Well I'm not that experienced with them just yet but from what I've learned it's best to keep them away from heat, so it could be contributing to your problems. As far as I'm concerned though, its mainly aesthetics.
About the glove box mounting, is there enough space around the box for adequate ventilation? I've heard that you should allow 1" of space around each side for adequate cooling, is that generally true? Has anyone ever had issues with the box overheating in confined areas.
Anyone ever mount one behind the head lamp under the fender? If you mount it as far forward to the headlamp bucket as you can get it and make a plastic or rubber fender shield it should be very weather proof, out of site, and located close to the electrical systems you need on the passenger side.
I have never done one, but there is a ton of space under those big fenders.
Well I mocked mine up today, what do you think?
Can you tell how I did it? :D
-Dan
Thats where mine is too, have my two step mounted right by it. Coil on the shock tower.
