While racing at the dragstrip, I was getting an ATF leak from somewhere. The fluid level is/was filled perfectly level with the fill hole. I initially thought the ATF was foaming up and venting out of the vent tube on my T45.
But that wasn't it. I took the cover/boot off the shifter and watch it carefully. As the rpms climb up past 5000 or so, the ATF fills up the well around the shaft of the shifter, and starts overflowing out (see arrow in photo). Its not foaming or anything -it just looks like regular atf, overflowing. Also, no ATF seemed to be coming out of the vent hole.
I pulled the shifter, and checked for the plastic cup-looking thing. Its there, and looks normal. Any ideas?
Shifter = MGW, tranny = Promotion built T45, fluid = regular, nonsynthetic dex/merc
