As you guys may remember, I had another thread troubleshooting my cooling fan. That problem turned out to be shorted wires. However, even though the fuse no longer pops I never did test the fan again. Well, after swapping the dizzy to solve another problem, I decided to let the Stang idle and see if the fan turned on. STILL no luck.
I had an Autoxray code reader hooked up and reading the PIDs; the ECT temperature slowly rose up over several minutes to 208*, and the fan never turned on. I shut the engine off at about 208.5*. A KOEO test does turn the low and high speed fans on, so the computer does have access to the fan and the fan does work at both speeds. My A/C system is discharged so I don't think turning on the A/C will activate the fan.
I'm at a bit of a loss as to what to check. Ideas? This is the last thing to fix on the Cobra clone before I can get it inspected and back on the road.
