ball joint question, 2005 gt with 20" saleen wheels
racer_inboston
310
boston, ma
Hey gang,
I'm running saleen 20x9 fromts and 20x10 rears. I put these rims/tires with no problem since the car had only 5k miles on it, now i have 35k miles and due to the winter, and the bumpy road to my house (about 1/4 mile) being super bad, I may need balljoints. I never lowered the vehicle since it does not look like it needs it. Eitherway, it has been pullin got the right for about 2 months and it vibrates from 30 to 80 mph. I decided to take it to have it aligned and tires balanced and they said I need the lowere ball-joints on drive's and passenger's side.
- Ok, now, should i go and buy another set of stock balljoints since my car is not lowered? any one have any ideas? I need to have this taken care asap so you guys with experience as to such would be appreciated.
Thanks
UPDATE! I just ogt off the phone with ford and they say you cannot replace the balljoints on 05-09 mustangs, they control arm is sold as a whole, part numbers: 7r32-3079-a and 7r32-3078-a..... if this is so, then how come Steeda sells theyr balljoint kits? I'm confused evenmore now
Correct the whole LCA has to be replaced to replace the bushing, according to Ford. I don't think Steeda makes balljoints though. What product are you looking at? Can you give me a link? The only thing I can think of what you're seeing is the Steeda bump steer kit
He was talking about balljoints, not bushings. And no you don't have to replace the whole lower control arm to replace the ball joints. RAYBESTOS Part # 5051322, or the Steeda X5's.
Nick
Nick
Oops, my bad. Correct, the balljoint can be replaced by itself. I know the 2004+ F150s have to replace the whole LCA when the bushing fails. I suspect that it's the same with the S197, too. Since we're talking about ball joints and I was just off than I guess you're good to go with the Steeda stuff. Long day at the Fantasy of Flight car show !!
Yes I was talking about the balljoints steeda makes (x5 kit) and stocker replacements from ROCKAUTOAuto. Funny how every dealership says they cannot be replaced and that the whole LCA needs to be replaced. If I can replace my balljoints then I will, anyone have a good write up for the s197's balljoint replacement?
Is it easier to replace Just the balljoints or is it easier to just replace the LCA?
Once again, I'd like to thank my fellow mustang gurus.
The Steeda X5 ball joints raise the spindles about an inch, which helps if the front is lowered to correct geometry but hurts if the front is not lowered.
Stock replacements will work fine for probably about the same amount of time as you stock ball joints laster, which is probably as long as any ball joints will last.
Either way, if you replace the ball joints just take the arms and replacements to a machine shop and ask them to press out the old joints and press in the new joints.
The other option is to go with replacement control arms, either stock or like the BMR arms. Either way that'll probably be about twice as expensive.
Dan
Great, I think I will take it the lower control arms off and have them press out the old joints and press in a new stock set. Thanks for the input. Geeeesss with only getting close to hittin' 40k miles, is this normal for a s197 mustang? I may have ot blame the short life of these original stock lower balljonts to the bad roads of new england.
Since you live in the north, it's possible that some salt crap (or other crap) got in the boots and corroded the ball joint. You might try re-packing the ball joint boot with fresh grease once a year in the spring time (after the snow has melted and the salt has been washed away). When you get the old joints out inspect them and the grease for anything obvious, corrosion or metal shavings, so on.
Dan
Dan
I highly agree ... I'm willing to bet combined with the environment and the road the car sees every single day is what did them in.
If you can get access to a balljoint press you can press them in and out on the car. You can manage with an air hammer and a large deadblow hammer if you are good, but I wouldnt use that method on my car. Otherwise take the arms off like others said, but I'd probably take them to an auto repair shop to be pressed in and out, rather than a machine shop.
Yes! I do have access to a balljoint press! It would be awesome if I don't have to take the a arms off to press them out out...Have you done this? any tips? and how will i know when the balljoint is pressed in enough in place? Being a bodyman by trade, I can use tools with common sence, but I really like to be sure prior doing it for safety reasons, ya know?
Apparently my ball joints are bad too. I've had the same dilema. I can't go with the steeda ones because my only has the stock 17" rims. I will either go with a stock replacment or the whole BMR arms.
DId the balljoints with stock replacements, took about 1.5 hrs each side, pressed out the old and pressed in the new right in there. car feels phenomenal again, had it aligned and fron tires balanced, feels like new.
tools rented from autozone:
ball joint press item # 557231-27023
oem ball joint separator #555664-27020 ( in case you need to smack it a bit to help the press do its work)
These adapters allow for lower balljoint press to fit properly on botton and top of balljoint.
AUTOZONE/GREAT NECK FORD BALL JOINT ADAPTER KIT:
#948082-27163
#948076-27166
Good luck
