- Feb 11, 2007
- 228
- 0
- 0
My car is an 87 carbed 302 with a duraspark setup
Cranked it today letting it warm up...It was running very smooth (went to the store and everything) then it just shut off like I had turned the key off and will not restart. Key on I have 12v at both positive and negative coil terminals. Swapped coils to one I had laying around, still cranks but will not fire even with a different coil wire to distributor. Coil is an MSD blaster but everything else is just a regular duraspark setup...I took out a spark plug and connected a plug wire to it...grounded to engine and it isnt sparking when I crank it...I did this with about 5 of them.
Im assuming it doesnt have spark because when I crank it, it doesnt even try to start if you know what I mean. I also have good fuel pressure to carb if that matters
any ideas?
thanks
EDIT...looked on the underside of the distributor cap and it looks a little corroded, but would it cause loss of fire simultaneously to all cylinders causing a complete shutoff?
any ideas?
thanks
