Making Brembo EVO Calipers Fit a Stang
The Cobra R Brembo kit is hellishly expensive.
MSRP is $1,150
Also, it requires greater backspacing than a GT rim typically has. The backspacing for the brake kit is 6.12"
Its an awesome kit though :nice:
http://www.fordracingparts.com/parts/part_details.asp?PartKeyField=5819
bdcardinal said:
another thing you have to consider is the thickness of the pads vs the stock rotors. they might not be designed to use a thicker rotor.
Yup, a little bit of engineering is gonna have to go into a retrofit. It's not a simple bolt and play
you will also need to make custom lines, i can almost guarantee that the thread pitch and size on the mitsu ones are diff. i know the cobra R kit comes with goodridge stainless lines. you will probably have to make custom ones, which are not legal in the US because they wouldnt be DOT legal.
ive fabricated brakes on a car with a friend, but he was experienced with CAD, and we did plans for it all beforehand. basically we put the old brake setup off of my car onto his 63 studebaker avanti. it took a lot of work adapting brackets, and finding the right bolts and fittings.
not to sound like an a-hole but if you have to come hear and ask what you need this task is proably over your head.
unless you are buddies with someone at a machine shop or something. even if you cad it up yourself 1 off pieces are not cheap.
I would call brembo's tech line and see what kind of insight they give you.
CRZYHRSGT said:
I've been known to fabricate a few things in my day, but brakes aren't one of them. I just don't like the idea of tampering with safety items, ESP. brakes.
:Word:
Brakes are one thing that should NEVER be compromised. In fact, installing any set of used Cobra brakes would be MUCH safer than installing some "rigged" EVO/Brembo brakes.
putting evolution calipers / subaru sti calipers is not impossible nor is it dangerous , i have it done on my car and am willing to make it possible for others , if you would like pictures just let me know gladly send them
