5.0 problems
bh88stang
I really need some help here. I bought a 88 5.0 GT 3 months ago. The car sat since 01, Has 68,000 on it. Car needed a fuel system. I replaced tank, pump, fuel pressure reg, fuel filter. The car ran good for about 2,000 miles. The car started bogging a little bit after putting 2,000 miles on it. Right now she only revs to about 3,500 rpm at full throttle only when im driving it. while driving it i will bring it up to the point where it wont accelerate anymore in each gear(about 3,500rpm) i hold the throttle in that spot, i can slightly back off the throttle and creep upto 4000 rpm or so. As the car gets hotter it will only rev to about 2,500 rpm while driving... . In neutral at full throttle the car will redline. . my fuel pressure is about 37 or so, my timing is about 13 pos degrees.
the car is throwing a fuel circut open (ground) code
and a thermactor code....
Please if anyone can help me out with some information I would really appreciate it.
What were the actual codes?
Did you install platinum spark plugs? They, a failing TFI, and a failing coil can all cause issues like you experience (amongst others).
Good luck.
Good luck.
81- Thermactor Air Circuit
95-Fuel pump circuit problem.
95- Thirmactor Air Diverter Curcuit.
Do you know what a Thermactor Air diverter is?
Clean your MAF sensor if you have one.... Check your tps and iac. Injectors might be crapping out cause that's good fuel pressure and timing. sitting that long a lot is gonna need cleaned up
IAC?????? I have a Haynes manual and its not mentioning
Inlet Air temperature Control? and how would i check the iac?
Code 81 – Secondary Air Injection Diverter Solenoid failure AM2. The solenoid valve located on the back side of the passenger side wheel well is not functional. Possible bad wiring, bad connections, missing or defective solenoid valve. Check the solenoid valve for +12 volts at the Red wire and look for the Lt Green/Black wire to switch from +12 volts to 1 volt or less. The computer controls the valve by providing a ground path on the LT Green/Black wire for the solenoid valve.
With the with the ignition on, look for 12 volts on the red wire on the solenoid connector. No 12 volts and you have wiring problems.
With the engine running, stick a safety pin in the LT Green/Black wire for the solenoid valve & ground it. That should turn the solenoid on and cause air to flow out the port that goes to the pipe connected to the cats. If it doesn't, the valve is bad. If it does cause the airflow to switch, the computer or wiring going to the computer is not signaling the solenoid valve to open.
Putting the computer into self test mode will cause the solenoid valve to toggle. If you listen carefully, you may hear it change states.
Code 95 Key On, Engine not Running - the following test path is for 86-90 model Mustangs.
The 95 code is because at one time or another, the fuel pump relay hiccupped and didn't provide power the pump when the computer told it to run. Sometimes this is a one time thing, other times it is a no run or runs poorly condition.
Suspect items are bad fuel pump relay, corrosion in the fuel pump relay socket, inertia switch, wiring damage , corroded connector contacts.
attachment.php
Using the diagram, check the red/black wire from the fuel pump relay: you should see 12 volts or so. If not, check the inertia switch: on a hatch it is on the driver’s side by the taillight. Look for a black rubber plug that pops out: if you don't find it, then loosen up the plastic trim. Check for voltage on both sides of the switch. If there is voltage on both sides, then check the Pink/black wire on the fuel pump relay: it is the power feed to the fuel pump. No voltage there, check the Orange/Lt blue wire, it is the power feed to the fuel pump relay & has a fuse link in it. If there is good voltage there & at the Pink/black wire, swap the relay.
Some Mass Air conversions neglect to run the extra fuel pump wire, and they always have a 95 code. See MAF - Mustang Mass Air Conversion - StangNet - The Mustang Network for more information on the Mass Air wiring conversion.
Clearing the codes:
Codes may be cleared by disconnecting the code reader or test jumper once they start to dump. Alternately, you can disconnect the battery negative cable for 10 minutes. If you replaced a sensor, this is the recommended way to clear the codes since it erases the computers learned settings. However, the car may run poorly until the computer relearns the correct settings. This normally takes anywhere from 10-20 minutes. Clearing the codes does not fix the problem that causes them to set in the first place. It just enables you to troubleshoot things and then check to see if what you did fixed the problem.
Problems in the Thermactor Air System would not cause the symptoms you are experiencing. You either have a marginal TFI or a fuel pump electrical problem. Of the two possible causes, a bad TFI is most likely since the problem seems to get worse as the engine warms up
