I figured if anyone on stangnet knows about C4s, it will be the 5.0 forum.
I seem to have a leak from the servo cover on the passanger side of my C4. Which servo is that? It is behind the hose in this picture I found online: http://www.supermotors.net/getfile/538242/fullsize/dsc_0970.jpg
Will the fix be as easy as replacing the gasket on this cover or does this indicate the servo is leaking and needs new seals? Is it possible to replace the servo seals without taking off the pan?
Sounds like it is true, if it doesn't leak, it's not a C4.
