Plug Readers , please chime in
Hi . Can aomeone take a look at the pic of my Plug . Can you give me your thoughts on what you see and how you would interpret it. Thanks http://img42.imageshack.us/img42/8089/hpim8912.jpg
I'm no expert but I don't see anything wrong. The center electrode is naturally small on those plugs. Side electrode looks fine. Can't see the insulator... is it cracked or worn or crusty with anything?
These are the IT22 . They are colder plugs i think. I used the TR6,s years back with MSD Dis 4 till it self distructed
Denso Iridiums are so expensive. I tried them and then I think I went to NGK TR-55. Kenne Bell recommends the TR-6s for me. Denso Iridium are great plugs... so are NGK. I get my NGKs for about $1.80 a plug. My Iridiums were like $8 a plug.
:flag:
They look pretty much fine. The red-ish color could have come from fuel additive or octane booster, but of course that doesn't much matter. To actually read the plug for AF ratios or to know if it is too cold/hot, you would have to run a clean plug and shut the engine off during the pull, then immidiately read the plug before even idling. All you can tell is if everything is generally fine in the engine.
You are correct. I do use a fuel additive to help increase the Octane. I,ve done this since the Supercharger was installed back in 1998 .
$3.50 and $15 HERE .
Ouch...! I have a guy here at Checker that if I call before he gives me a 15% discount. And some other discount just for acting cool to him on the phone.
What supercharger are you running? I think the NGKs might work fine for you. But your Densos look fine. Are you having problems?
I had a problem with spark blowout so the MSD was installed to use with the NGK,s. When the MSD blew up , the replacement was $520 Cnd $ . To my way of thinking the plugs were a cheaper way to go as long as they worked , and they did . I found nothing wrong with the NGKs , just had to change em each year and would not work for me without the MSD.
Plug looks fine. I had thoes but swapped them for NGKs cause my blower was blowing them out.
I will prolly get flamed but I am gonna swap in some E3s soon. I am not one to believe hype but I keep reading good things about them. Good for a horse or two plus a more complete burn so lower CO2 and better mileage.
By my old job there is a small parts place and the guy has a little coil demonstration set up and seeing an E3 right next to an Irridium plug it was amazing how much brighter the spark was.
I know they are more expensive but younever have to replace them :shrug: Only thing that made me wonder is they cant be gapped :shrug:
