Symptoms started a couple weeks ago and are as follows:
1. AC mostly going through defroster vents, but will occasionally switch back to regular vents.
2. If I shift into neutral and coast to a stop the RPMs will hover around 1800rpm and eventually go down to normal.
3. When idling the engine will suddenly switch to a different sounding idle pattern - doesn't sound normal.
It's not a question of IF I have a vacuum leak, it's WHERE is the vacuum leak? Are there any common places I should know about? Any type of test I can perform to help hasten the process? I'm pretty inexperienced with hunting for leaks in the vacuum system so I'd be extremely greatful for any advice you veterans of the art could provide.
Thanks in advance,
Andrew
Thanks in advance,
Andrew
