Went to the track tonight; Got some problems/questions
sneaky98gt
2,387
144
114
NC State University
I'm gonna go ahead and apologize for the long post. lol
Finally got back to the track again tonight. I'm happy I was finally able to run the 1/4 tonight. However, I'm EXTREMELY disappointed with my times, and I'm trying to figure out why I'm not running quicker than I am.
Last time I went to the track, I ran a 9.67 @ 73.37 mph. (1/8 mile) Tonight, the best I could muster was a 9.81 @ 72.73 mph in the 1/8 and 15.21 @ 90.83 in the 1/4. The problem is that the new times are after I installed Steeda underdrive pulleys and PI cams. Total mods: PI Cams, PI Intake, Steeda UDPs, Delta Flows, CAI, and tires sticky enough to hook the car. I think I remember watching a video of 98cobra281 running something like 14.1-14.2 with similar mods + exhaust. I just don't feel like a 5 speed + exhaust makes a full second of difference. While I was at a different track than the first times were run, I really thought I'd do better than this. Just so we all know, both tracks are at the same altitude, and it was no more than 7-8 degrees warmer tonight than last time. I've got a couple a theories on why I'm doing so bad, and was wondering if anyone else here has any suggestions or otherwise.
A) The track sucks (although I was hooking with close to similar 60 fts). I will be testing this theory tomorrow night as I'm going back to the first track, although it is only 1/8 mile.
B) Something is wrong with the car.
Assuming that A isn't the problem, what could be causing these uber-slow times? Here's some thoughts I've had.
1) Air filter could have something to do with it. I haven't cleaned it in a while, so I'll do that tomorrow. However, it's only been less than 2 months since last time I run, and I have cams and udps now; don't really think air filter would make that kinda difference.
2) Degreeing the cams? I don't really think so considering they're only PI cams. What do you guys think? Doesn't make sense that they would decrease my times.
3) MAF sensor? Once again, I don't really think so b/c the car is running smooth. It isn't missing or anything like that. Car seems to run fine.
4) Needs a tune. I know it would help, but I still don't understand why my times have gone down/are so horrible anyway. I wouldn't think it would be off that bad.
5)There is a problem w/ the ECU. I don't know why there would be, but I never did unplug the battery when doing the cams. Will it relearn the cams anyway? Or do I need to unplug the battery and let it reset?
6) Vacuum leak? I don't see this being a problem b/c I thought that leaks cause the car to run rough. My car is running smooth.
Overall, because the car is running smoothly, I don't think there is a problem with fuel or spark. While I could be completely wrong, common sense tells me this isn't the problem.
What do you guys think? I'm pretty sure I got a problem somewhere, I just don't know what it is nor where to look. Any advice would be graciously appreciated. Thanks.
-Will
1) why don't you post the 60 foot and 330 foot time for the different runs.
2) what was the weather like today verses the other runs
3) are the 2 tracks at different altitudes
just to make sure the cams are timed right what is your cranking compression
You don't have a tune for the cams and intake? You realize the car will not make more power without the computer allowing it. All 96+ cars are like that. You can mod the hell out of them but the computer caps the hp levels until its been modified too. :shrug:
What are your sixty foots and how was the weather?
I ran the time in my sig with the mods listed, no tune and on general altimax hp tires.
If the cars running fine you may just need better weather and/or to work on your launches.
I ran a 2.16 on the run earlier this year, and a 2.20 last night. Traction was not an issue; I did the same thing last night I did 2 months ago: I built it up to 2000 rpm and hammered down on the 3rd yellow. My 60 being less was not due to less traction.
60's don't make a difference in the mph do they? I thought that as long as you didn't have wheel spin the mph stayed the same. Why would my speed have decreased? This is what worries me.
330's, 6.32 2 months ago vs. 6.37 tonight. I don't know what this tells us, but there they are.
Yea, like I said, I know a tune would help a lot, but my speeds and times decreased. I really don't know why they did. That's the problem.
Chucks98's time is almost a second and a half faster, and has mostly the same thing I do + an x pipe and T/A, with no tune. I don't think an x pipe and T/A (+ a 5 speed if it's that) is gonna make 1.5 seconds difference.
Thanks for the help.
-Will
Actual weather, I don't know for sure, but I'd estimate about 75 degrees with a medium amount of humidity. The humidity was probably higher than last time I ran, but it wasn't all that bad. I'm gonna be running again tonight in very similar conditions to last night, only at the first track I ran at. I'll find out for sure if the track is the problem or not.
-Will
It tell me where the car was slower. from 0 to 60' it was .04 slower than your other run but from 60' to 330' it was only .01 slower than your other run but from 330' to 660' it was .09 slower. Which gears were you in and did you change shift RPM? :shrug:
Code:
2.16   2.20  60'   -.04
6.32   6.37  330'  -.05  -.01
9.67   9.81  660'  -.14  -.09
i had
cai
steeda udp's
steeda t/a @15*
o/r h @ cat back
373's
pro 5.0
pi intake/ cams
i made 225rwhp/270rwtq, and i went 14.1 w/ 2.07 60' @ 95.xx at full weight @ 1/2 tank
my friend has the same mods, and powerheads stage 1 cams, and his best is a 14.6 @ 95.xx
It's the stock auto transmission with 3.27 rear gears. I let the transmission shift. I didn't notice it really at the track, but from driving around home here lately, it shifts right at about 5500, about the same as before any of the mods I've done. That's something else I've kinda thought was weird; I thought it would shift a little later b/c of the more hp it should be making, but it's been shifting at 5500 +/- 50 or so rpm ever since I've had the car, depending on how many rpm I'm turning when I go WOT.
I'm about to go clean it up to head down to the track tonight. I'll post up my times from tonight soon as I get back.
-Will
-Will
Thats because the computer is set for 5500 shifts +/-. When you remap you can change the WOT settings :nice:
something is wrong
alot of factors to consider, I have never had an auto, but I ran 103-105 all day long with my 98 with the PI swap and stock tune. On my 97, I ran 77-78mph in the 1/8 with the stock tune with stock heads/cams and just the PI intake.
If your auto is shifting at 5500rpm, you are loosing some ET and mph there. I shifted my 98 at 6k, and my 97 with just the PI intake at 5800rpm.
You need to post DA's and the entire run.
Well, got back a little while ago. Here's what I did tonight:
60' 2.20
330' 6.42
1/8 9.80 @ 72.8 mph
The exact same as last night. The track isn't the problem.
Outerbanks Speedway elevation: 10 ft. The temp tonight was 75 degrees with 80% humidity. Yea yea yea, tell me about how bad the weather is, but the weather isn't the problem, or not all of it anyway. Well, I did some digging around in my desk drawer and found something I forgot I kept: my timeslips from the first time I ran my car.
My first passes ever were made on this same week last year, at the same track. My car was completely bone stock with some really sucky 245 tires. I ran a 9.61 @ 73.76 with a 2.18 60'. In case any of y'all didn't notice (like I didn't until here recently), I have lost time and mph with every mod I have done. Something is wrong. My bone stock car was doing .2 sec and a solid mph faster than my car is now with CAI, catback, Steeda UDPs, PI Intake, PI cams, and a much better set of tires. Something is very wrong.
Someone tonight at the track, who knows a pretty good amount about cars, said that a tune would probably help a lot. While I'm not doubting that at all, and I'm probably gonna get one soon anyway, I just don't think that is all of the problem. There are several guys on here with very similar mods w/o a tune running WAY better than I am. Oh yea, almost forgot. I reset the ECU (unplugged the battery and MAF for a little while) and cleaned the air filter before I went tonight. That obviously didn't solve the problem.
My dad suggested something like maybe a bad O2 sensor? He's pretty much guessing, but his reasoning is that maybe something like that is leaning/riching the mixture up and it just isn't making the power it should be. It makes sense, but we really don't know. Maybe MAF? Because the car is running smoothly, I'm agreeing with him and thinking that the problem is something along those lines.
Anyone have any other ideas? Anything is very much appreciated. I'm kinda getting ticked with my car right now...:nonono:
-Will
Just another thought. Could the IAT sensor cause loss of power? I don't really know how it works, but I noticed something with my car when I swapped the cams, but didn't think anything of it at the time. Where the sensor plugs into the CAI, the little rubber bung is kinda worn out. Not a whole lot, but the sensor is not super snug inside the bung.
Now lets assume there is a problem. Either the IAT sensor is bad or maybe it isn't sealed very well into the intake (which easily could be) and there is a leak. Could this cause any kind of problem like I'm having? I guess I could swap the stock intake back on to find out. I might do that. But I figured I'd ask anyway.
-Will
The o2 sensors aren't used at wide open throttle because you then go into open loop. a leak at the iat sensor should be fixed, but the leak would be slight and not much of a factor at wide open throttle. If you're shifting at 5500 rpm, that's to low. The pi cams are designed with more high rpm power in mind. My auto shifts at 6000. Try shifting manually, or get a tuner that you can adjust your shift points with. If you shift maually you need to shift early, beacause of the time it takes for the shift to complete. Try say 5500 rpm and by the time it shifts you might 5800 rpm. I bet if you shift at higher rpm's your times will improve a lot.
