Trick Flow 2V N/A 408hp on Horse Power T.V.
+1 at gearbanger
Ithink it's great that there is an aftermarket 2v head now, and I know we don't buy our cars for mpg, but even slapping a blower on stock heads and making more power doesn't reduce mpg by that much, especially if you stay out of boost when not necessary :shrug:
Either way these are sick, and might make their way onto my car in 4+ years when I graduate and they're cheaper :D
along with cams, what else would you have to modify in a 2v to compensate for these heads?
Nothing.:nice: except a dyno tune.
It’s not going to be a necessity to make them fit, but I would imagine you'd be going through a lot of trouble and money for nothing going with anything less than a high flow aftermarket intake/throttle body and a good set of 1 5/8 to 1 3/4 headers (Long tube ideally) and high flow mid-pipe and after cat.
I'm sure it wouldn't be as extreme by comparison, but it would be running a set of ARF 205 on an OHV engine, but leaving all the rest of the stock hardware in place.
In short, unless you're planning on upgrading ALL of your supporting hardware to sustain the kind of airflow these heads capable of moving, you're probably wasting your with them.
In short, unless you're planning on upgrading ALL of your supporting hardware to sustain their airflow these heads will move, you're probably wasting your with them.
Agreed, but so many of us have already upgraded (to varying degree) the air in/out part of the equation outside of the engine. Finally, something to make my K&N filter make 20hp! :D
btw, I assume these heads have better (more) spark plug threads. Hopefully plug blowout is a thing of the past with these heads.
I believe you are correct. Thats worth some money right there!
I'm so glad Trick Flow has finally come through for us. I think these heads will really help get our 2vs to new levels (NA or blown).
i hate to say it but my head cam intake 2v with stock bottom end did 310rwhp with just stock ported heads and stage 2 cams with the trickflow intake.. so the trickflow heads did not make that much more then mine did.Oh and i see in the pic a elec water pump and no pulleys on the motor... that makes up some power.. i still have a stock water pump and all the pulleys on the front of my motor.
money
Vt stage 2 cams 600.00
heads used 500.00
trickflow intake 750.00
1850.00
i couldnt agree more.these heads are good for a few reasons,the removeable/replaceble cam journals is an excellent idea,no more **** head just because of 1 **** journal,just replace it.also they are drilled to accept both 11 and 13/14 bolt valve covers,and the valves have been arranged diff and the combustion chambers are diff to begin with and come in varied sizing.BUUUUTTTT,also realize that like stated cars are already making these kinds of numbers with whats out there.my car made 318 with the mods in my sig,stock lower intake,8.5:1 compression and i just found out i had leaky valves and **** springs.these heads are good out of the box and can be ported way bigger then a factory casting but really they are comparable to a stage 2 flowing head when they come out of the box.plus my car is running full belt with a/c,tensioner,alt,p/s and such.those numbers are not that impressive for what they have,prob a high compression motor too and torque seams a tad low.
just my 2cents
well i have bbk EL shortys and BBK O/R X with American thunder two chamber flowmasters. think thats enough flow for the exhaust? i know LTs would make more sense. I would buy a new intake with these badboys anyway. maybe just slowly build my pile of stuff and install it all in a weekend. :) im starting to get into this performance enthusiast hobby alot more. *mod bug attack* :shrug:
ya i contracted that bug years ago and just cant seem to get rid of it. lol!
I have the TF's on order....
Well, I have had the TF's on order for 6 weeks now and they keep pushing back the date.:mad: These heads should go nice with the new parts I have already recieved for my '00 Twin Turbo Mustang 2v.
I have the following parts:
*HP Performance twin turbo kit (2 - 50mm turbo's), k-member, intercooler, coilover suspension.
*MMR 950 stroker shortblock (5.0L stroked cobra block)
*Elderbrock Victor Jr Intake w/ 75mm Accufab Plemun
*MMR Stage II Turbo cams
*TKO 600 5sp Tranny (Powerglide would have been better I know)
*Spec stage III Clutch set
Parts I need:
*Complete fuel system
*Fuel injectors
*Tuner/tuned
What kind of power should I make?:shrug:
Frank
Parts I need:
*Fuel injectors
*Tuner/tuned
Frank
What amount of boost will you be running? :shrug:
Anywhere from 800 - 1200 HP (flywheel) depending on parts and boost level and still be very streetable :D
these heads are part of a build I would like to do. I just still dont think I can reach my goal of 400rwhp. Im looking to run low 11's @ around 120ish all motor. My plan was a 5.4 bottom end trick flow heads comp 270's with trickflow intake. Cobra R hood should clear. The problem of lack of long tubes may put the power I want on the table. FRPP shortys seem to be the only option. I have not been impressed with current 5.4 swap power and track times. Maybe these heads are whats needed to breath for the power I want. Might even be able to hang with some chevy's.
A 5.4 with these heads and the TF intake with some good cams and a 5-speed I bet you see 420+ rwhp. :nice: A little spray will push you past 500 :banana:
They are already making more then that on a 4.6 :shrug:
So that is not a correction on your part. :nono:
I agree. We've seen numerous threads with dyno sheets even of people with 300-320 rwhp with most of the bolt ons so I don't see how with most of the bolt ons and the TF heads you couldn't be pushing 340-360 rwhp. And thats on a 4.6, it stands to reason that a 5.4 should be able to get close to or over 400 rwhp.
