My car has an awful sound coming out of the front end. Sounds like the right front spring is chewing on a brick while popping a joint out of place
. I took the wheel off lubed all the rubber I could see, cleaned the spring seats, and changed the right, outer tie rod end. The noise improved but did not go away. The sound is usually heard when turning the wheels without forward movement and also over moderate to severe bumps. I really didnt see anything broken when I was looking around in there but I aint no mechanic. Any ideas on what to check?
