335/30/20?
LaserSVT
3,548
233
Will they fit on the rear of a S197? What is the widest rear you can fit on one for a 20" rim size? Rim would be a 20x10.5.
This is a curiosity question and would be on a GT500. :nice:
Any pictures of big ass 19" or 20" wide width rears would be cool too. :cool:
Realistic size then. The GT500 (2010) has 285/35/19s right? It cant put the power down at that size and the 19s look small on the car. So to step up to a 20" wheel is a 305/30 about the limit?
its not that bad on level ground, my street is very convex on both sides.
and nah, they are 325/50/15 nitto drag radials. 555rs.
i plan on swapping them out to M&H racemaster drag radials, m&h run skinny, so a 325 will probably be pretty similar foot print to a 305 or 295 even.
if they hook good enough i'll go with a 26 inch tire, and be able to pull some decent 60 fts without bogging.
305 is the biggest u can get away with on this car...
So it looks like 305/35 in DRs or 305/30 in Michelins are as big as can get in 20" wheels on here then huh?
The 2010 looks a bit lower and the 20" wheels/tires will fillthe well enough to only need a 1" drop. They make them that small?
