I got fel pro head gaskets with the pre flattened steel ring around the chamber and they have "front" stamped on them. The question is, what side faces up? And what water passages are supposed to be blocked? Seems like the rear passages are the chosen ones to be blocked. I am also having a hard time with contradicting info on the proper way to install head bolts. I got ARP bolts. Do I use anti sieze on the top bolts or oil or dry? And what is the best thread sealer to use? I have permatex thread sealer. Is that good enough? Sorry for all the questions. Just dont want to screw up being that I'm running 12lbs of boost.
