Going to the Track Tonight
Allright here it is:
Worst of the Night:
.324 Reaction
2.5435 60FT
6.4101 330FT
9.3648 1/8th
84.95 MPH
Best: I dropped the tire pressure
.2443 RT
2.200 60FT
5.8537 330FT
8.7647 1/8TH
85.41 MPH
The drag radials were 235/60/15 Mickey Thompson's. At 16 PSI. Kept spinning in first and second. Even tried to baby it. So yes wider tires are needed. Extremely hot outside. Humid too.
Thought? Besides my 60FT times. YES they are killing my times.
you dont NEED to go with a bigger tire to hook up, you can put money into your suspension also. My buddy with a turbo h.c.i and a 235 mt dr is down in the 1.4x and was running low 10's..
not only weight but adjusting your ic!! What kind of shocks/springs do you have??
Just another thought how would you rate the quality of your track? Do they prep much the night you went? Did you switch lanes? Just wondering....
Drew
Drew
Your tires aren't the problem. The MPH is good but the 60ft sucks bad. Sounds like the weight isn't transfering, and I mean none what so ever.
Yes the quality does suck very much. But still the best I could get was 2.1 60 foot. Yes switched lanes. They don't prep it too well.
The weight does transfer, not the greatest but does. It has steeda sport srpings and shocks. And Steeda upper and lower control arms.
It's tough to really give you advice over the internet, ya know? Next time lower the tire pressure to 14 and give those tires some heat. Don't expect good 60' without a more drag oriented suspension setup. It all depends on what your plans are with the car. I'd put money down that you could get it under 2 seconds as the car sits....
Drew
Drew
I could on a better preped track. Well it is an convertible so no drag suspension.
