- Jul 11, 2009
- 15
- 0
- 0
Hi Guys,
recently I installed a Tork Tech M112 intercooled kit on my 2000 GT (Manual tranny), the company claims that a stock GT with their kit should reach +360rwhp @10psi, and from what i have seen here a couple of members here has exceeded that with some bolt ons only.
My car has the following,
After i got it properly tuned, i tested it on the dyno to see what it got, and here i got very disappointed, only 330rwhp/328rwtq, the max boost was 13psi.
And something to add here is that my fuel pump has maxed out @5500rpm
the car has a SVT Focus pump with a 42Lbs inj, do they all max out @330rwhp?
My tuner said that i should solve the fuel problem and then he would advance the timing few more degrees and see.
I asked Tork Tech tuner and he said 13psi is high; it might be my exhaust not flowing well and restricting the car from performing well.
Im really confused here, should i solve the fuel problem first? Or change my exhaust setup?
- BBK L/T
- O/R X-pipe
- 2.5" exhaust (locally fabricated) with MagnaFlow mufflers welded in
- COMP cams XE-262AH
- 4.10's
