Picked up a Tuares 3g alternator and I'm finally getting around to converting, though I have a couple of questions.
Got the pulley off of both, and as a shim I used the 1G alternators lock washer and then put on the pulley and torqued it down to 77lbs. Is 77lbs enough to satisfy safety requirements? I figured if the 1G used the lock washer then I could use it again as a shim, then the pulley, followed by the pulley nut.
Found a diagram on the 3G conversion and obtained the 175 amp mega fuse. My next question is about the 'I' terminal wire that is supposed to go to the starter switch that is hot in run/start. What and where is the starter switch?? (starter solenoid?)
It appears I won't be using any of the old alternator wires (correct me if wrong please), nor my electronic voltage regulator. I'm not concerned about deleting these wires as I'll be getting one of those EZwiring 20 circuit harnesses probably in a few months. I just need to figure out where the starter switch is..
