Exhaust problems need advice?
MY 85 GT
1,852
208
104
New Jersey
Ok i just bought the new American thunder cat back with the new super 44's..It sounds ok but im thinking something else is wrong...Ok here is what the senireo is...The car is all stock except off road H-pipe air silencer removed and a catback...When i bought the car i did nothing but removed the silencer and put in a K&N panel filter it had old flowmaster 40's welded in the stock tailpipes with an off road H..now a few months ago the rear let go so i put in 3.73's this is an AOD car now with the gears the car shifts much faster and is in top gear quicker even on local streets to me the car lugs alot and i noticed now the car pings which it never did before the gears...werid no...?? Ok the timing could be advanced and now with the gears being it shifts quicker and lugs i hear the pinging...But here is my question?...Being if the timing is to far ADVANCED...with it change the tone in the exhaust making it sound horrible...if i drive it slow and ride next to cars or a cement divider you hear this weird almost like pinging rattle noise in the exhaust..But i dont think it could be pinging at say 15- 25 mph could it be?.I dont have a timing light is busted..lol could i mark the dist and move it a little to stop the pinging and see if it changes the exhaust tone...will it being to advanced make exhaust sound rattlely...or is it just the Off road H pipe causing this noise being it has no cats you hear the exhaust pulse?..any help would be great thanks..Oh yeah i still dont get why the car pings now but never did and all i did was put in 3.73's....
sure its pinging and not just an exhaust leak? good way to check is,with the car cold, put it on jack stands, start it, crawl under and feel for leaks, will be cool enough for 2 or 3 minutes without burning your hands.
(I think) should have less chance of pinping with 3.73s than stock, 3.73s will put less load on the motor.
you can turn the dis. counter clockwise, just a tiny amount, to retard it a few degrees.
Ok i marked the Dist my timing light is busted turned it back a hair and wow the car seems to be running much better...Could it be possible it was way to advanced ?...will that cause a car to run worse not better..the car seems like it has much better thorttle response and seems to have picked up power so my questions is being to advanced make worse power? to a point were retarding it a little helped or at least bringing it back to a good timing spot?...
take it to a reputable shop and have the timing set? :scratch:
This is on my 93 GT daily basiclly its all stock catback,off road H-pipe and K&N panel filter and 3.73's...the car always acted weird since i got it last year.. i put the gears in i noticed how much more it was pining so i turned it back a little today and wow what a difference in how it runs...It seems to have more power then before..thats why i asked if being to advanced would hurt performance because now i know it has less timing but feels so much better...:shrug:
I'd have a shop (or a friend) set it back to base (10*). There's no telling where it's at. At least if you set it back to stock you know where youre working from...
Well this morning i marked the Dist and turned it slightly and i have no more pinging this car used to sound like marbles thats how bad it detonated..i used to hear it and back right off the gas i knew it wasnt good...But like i said this car for a year never ever made a noise i just noticed it the last few months since i put the 3.73's in this is an AOD car so i thought being the car shifted faster in was in a top gear quicker and had a huge load on it at a lower speed so thats why is was pinging i always ran regular gas i had to put in super but still heard it ping slightly so im sure it was way TO advanced...Im going to be picking up a new timing light this week so i can time it right on the money but for now its better then the detonation it had....
