I use Gasgacinch to seal up these type gaskets. Make sure the surfaces are clean, apply the Gasgacinch to the gasket and surface, let dry, then apply the gasket. Repeat for the other side.
Never had a leakage issue using this stuff. It's sorta like a mild contact cement.
RTV is for intake manifold and oil pan corners. Yamabond is for motorcycle cases. Weatherstrip cement is for weatherstripping.
BTW only use it on the pan or valve cover side in those applications.
