the dry kit is sold cause its cheaper and eaiser to install.
look at any kit over 150hp shot, all wet kits
how is a dry kit better?
will a 100hp dry kit make more power than a 100 wet kit?...... yes, definatly, lean runs strong (oddly)
Is a 100 dry kit safer than a 100 wet kit? hell no
Funny enough a diesel runs stronger when richer, other side of the spectrum. lol
Installation is about the same. The dry kit has more parts, and costs more to make. Wet kits worked fine for years with carbs. When the long runner intakes came in with EFI, engines started puddling fuel up in the intake with a wet kit. You can spray up to about 225 on a dry kit with some custom work. After that, you just run out of fuel pressure. You can't spray any more than 225 through a single nozzle wet kit anyway.
Kurt
if you ditch the nitrous regulator and go with a single solenoid you can run more than 225. that is if you have a block that can handle it and injectors that can supply the fuel. its all in the tune. mainly the maf transfer.
there is no point arguing opinions, wet kit is more expensive than a dry kit-fact. wet kit is basicly a dry kit minus that regulator thing that jumps up the fuel pressure, but also has a fuel soliniod and fuel lines.Installation is about the same. The dry kit has more parts, and costs more to make. Wet kits worked fine for years with carbs. When the long runner intakes came in with EFI, engines started puddling fuel up in the intake with a wet kit. You can spray up to about 225 on a dry kit with some custom work. After that, you just run out of fuel pressure. You can't spray any more than 225 through a single nozzle wet kit anyway.
Kurt
FYI- Ive installed and used both
most people think you need to step up on the injector size for a dry kit but thats not true in most cases. the typical off the shelf dry kit runs on elevated pressure at the fuel rail. obviously the increased pressure makes the injector spray more than it would at stock pressure. therefore you chose your injector based on your N/A requirements. the only time you would need to run larger injectors on a dry kit is if you have a custom kit that you run on stock fuel pressure. in that case you would much larger injectors than required for your N/A requirements along with a custom nitrous tune. it can be done but its not very common. just get the pump and you will be good to go.
