What do you guys think about yellow headlights???
BLCK95GT
93
TR NJ
Soo check this out.... I sell HID kits around here locally as a sidebusiness.... I sell just about every color, normal colors and exotic colors and ive changed the color in my car soo many times....
Ive had alot of thoughts about yellow till i tried it.... And it seems like its a love it or hate it kinda thing... Alot of friends told me they think it looks ugly, but on the other hand, they have exotic colors which suck for usability,..
Here it is... 3000k yellow, with 55watt ballasts rather then 35... 3000+lm output.. IMO they put out the most usable light for it lights up the wholeee roaddd....
and high beams on
I got my bash shield on because i have a feeling alot of people arent gonna like it... im not fully sure i do... i might take them out and just put a nice 5000K color in.... but i kinda dooo like it... .. ughhh decisionss..
generally all different kits use the same wiring....... 2 clips at the bulb go to the ballast...... anddd the factory 9007 clips go and clip into the ballast as well.. thats how it should be right....... crapp i forgot about bixenon....
for bixenon, theres 2 options..... a mechanical bixenon and a dual filament bixenon...
the dual filament like the name says , basically looks like 2 hid bulbs on one base.... and operates on 4 ballasts.... its probably the brightest bixenon you can buy because when you just flick the high beams, youll be running 2 sets of hids consecutivily... also, i can let you customize the colors of both, the high beam bulb and the low...... pointless unless you wanna run an exotic illegal color that you can just switch off and the normal white color when your near a cop
35 watt normal colors 220......... exotic 245
and there is a mechanical bixenon kit... it uses 2 ballasts and a single bulb... and just deflects the bulb up and down when you flick the highs....much more practical and cheaper then the first set.
160 normal colors... 175 exotic
Yea mine is a mechanical bixenon i have 3 wires off of a standard 1 piece bulb set up with big silver ballasts. I had 5.3k and now 6k but i cant use them since i ran over the harness :nonono:
The harness had a black box filled with silicone and a chip. I think stangmods is looking for a new harness for me.
i can probably get that harness for you from my supplier... if you want, ill give them a call tomorrow.... does the harness also have a relay??? i might be able to get that for ya cheap
Maybe in the little box... It had leads to go to both ballasts a spot that pluged in to my headlight. and then a ground strap and a power strap with an inline fuse.
Ballasts look like these
http://germanhid.com/images/HID Conversion Kit.jpg
Headlights have 3 wires coming off of them
