hey guys need alittle advice here...
I am currently trying to get my mustang running the way it should. I have a stock bottom end with 60cc afr 165's, 1.6 fms rockers, e-cam, Edelbrock Performer RPM II intake, fms shorty headers, off-road H-pipe, magnaflow catback, autolite plugs, fms wires, msd pro billet distributor n msd coil, timing set at 12 deg, 70mm accufab tb n spacer, 80mm pro-m mass air and 24lb injectors, Anderson power pipe, A9L comp, 225lph pump out back and Fuel pressure set to 34.
everything is brand new (except the bottom end) and hasnt seen the road regularly yet, including every electrical sensor (including O2's) and i literally went through every single wire in every harness to make sure everything was ok. the car surges for a couple of mins on cold start up but smoothes out n idles great. i took it out on the street a couple times to see what it feels like and at part to almost full throttle it bogs like crazy. then, when it feels like it, it tears ass and takes off like a maniac like it should....it also stinks like its running rich most of the time, even at idle.
I'm wondering if my combo isnt correct for my setup. is my upper intake too big? am i doing something wrong? timing/fuel? i dont want to register n insure it only to be disappointed. other than thinkin that the performer rpm II might b overkill i've tried to match up everything without going crazy. I want to get it tuned but I want to be able to drive it somewhat close to normal first. also the bottom end seems to be alittle tired and i think the rings are going because its smoking, not horribly though. I was going to just get another 306 to replace it but i want to know that this combo will work. I've done similar, mild setups on my other stangs and never had this problem before...
If anyone can help I would appreciate it. PLEASE! i'm tired of staring at scratching my head while it sits in my driveway after spending all that time and money......thanks
