bent k-member?
well i think its bent. i already replaced front struts and lower control arms. i stil cant get the caster in spec even with caster plates installed. who makes a good k-member for a 94 gt. it has the 03/04 cobra lower control arms already.
If you want to get aftermarket K-Member that is strong and take everyday abuse, Get Maximum Motorsports K-Member,
Everyone will have different opinion on this but I personally use AJE RR K-member and am very happy and it is "almost" daily driver car, I haven't had any problems, But it is hard to bend the factory K-member, Was the car in an accident before?
Good luck :)
tie rods are fine. they only control toe adjust. it was in a slight accident where i had to hop a curb. no body damage though. a tie rod was replaced due to that. if i buy an aftermarket k member i want to re use the cobra lower control arms
Good luck :)
i have an AJE as well. i drive it all the time. very happy with it
my son bent my previous k-member a year and a half ago when he lost traction and went over a curb (partially due to driving on summer tires in 20 degree F weather). that was also an AJE. the new one i have now has a different design and looks much stronger than the previous one.
Note that if you bent the K member you could have twisted where it mounts and the new K member will not fit without modifications. I have a buddy going through the same process right now. I would suggest taking to a body shop and pay the intial 100-150 bucks for them to check it out. Then it usually only takes a couple more hours to straighten it. The average per hour was 55 bucks around here in Texas. So it ends up being 250 or so for a straight frame/k member.
Just my 2 cents.
Just my 2 cents.
I second that. If it was that bad enough to bend the k-member the mounting spots may have shifted also.
You can re-use the cobra control arms with AJE k-member, But why? AJE has the control arms you can use with out going coil overs. (MM k-member, you will have to go coil-overs)
as far as frame, just take it to the shop and see if it's still straight, i doubt it's bent that bad, nobody here can tell you if it's bent of not. take it to the professional and get it looked at.
Good luck :)
