Electric fan in your classic?
robbz28
775
Epps, LA
I know several of you probably have electric fans in your old mustang. If so I would definately like to hear your opinions. I have done a lot of reading and the fan of choice for many hot rodders is the coveted "taurus" fan. I looked into this, but I really didn't want to have to do all that wiring for the high and low speeds. Anyone run another kind of fan? Also what CFM do you recommend. Summit has a 16" 2200 cfm fan for around 90 bucks, along with a thermostatic wiring harness for 45 that kicks in at 185 and off at 175, does this sound like something that will cool my little stock 289 automatic 67 w/ a/c?
Oh yeah....in louisiana
The taurus install isnt that hard. I didnt wire up both speeds mainly because i thought i had a coooling problem so i just use the high speed.Now i find my car runs in the 168-175* range and i have to turn the fan off just to get to go into closed loop to tune it.But to wire both speed wouldnt be much more work.
mark8 radiator+fan assembly, single speed, however runs too strong IMO w/o PWM controller, and needs expansion tank.
Get a DC Controller unit and it will run at a variable speed - I have a MK8 fan and DC Controller (The FK-50P )in my 93 5.0 and I plan on using the same setup in my 67 coupe. The only other thing needed is a higher amp alternator since the MK8 draws about 30amps.
Fan Control
I have one on my truck. Its a single fan, unknown brand. I do not have it wired to a temp sensor. Just a switch.
It keeps the stock 302 within normal temp limits. Even on a hot day. I will have to dig around and see what brand it is.
well, that $150 DC controller is pretty much what I am looking into. I assume it uses pwm for rpm control. I love guys who charge you $150 for a black box and when you click "Theory of operation" they give you :nono:
Nice setup, I like the way that looks, Yes i have the factory radiator, but its in real good shape, you dont want to sell that aluminum radiator on the floor there do you?
I sure would sell the radiator but...It is long gone. I put the big radiator in about a year ago and someone scooped up the old one real quick!
There are a lot of us Fox guys who use the DC Controller, I have had mine for over 2 years on my 93 which is also my daily driver. It works great in traffic with the A/C on in the Texas heat.<?
How it works - it is programmed to turn the fan on in a few situations, first, when the coolant temp gets hot enough (you can set it to 165, 180, 190 and others via jumper pins). Its not just a one speed on and off, it ramps up fan speed according temperature and when its cool enough it slows the fan down - it constantly takes temp readings and adjusts accordingly. The other times it comes on is if you have under drive pulleys, it will constantly stay on at 10% power, if you have A/C in your car, it automatically goes to 50% power when the compressor kicks in.
Do a search in the 5.0 section and you will see tons of threads on it and how good it is.
Federico Garza
Taurus fan here in a 65 coupe, using it with a 3 row copper/brass original type radiator, hands down one of the best mods to the car...
I don't know how you got yours to fit with the stock radiator. I had to cut out the radiator support and move my aluminum radiator forward and yet only have about 1/4" of clearance to the WP pulley.
Good:
Cheap & available at salvage yards
Pulls air like crazy
Has two speeds
Can get a new motor at almost any parts store
Bad:
4 1/4" thick
draws a lot of amps
Need separate relays/controller
that's what I was gonna say, how the hell are you guys running the taurus fan in a 65/66 car??
I had to cut mine down literally almost in half, and now it looks so bad I won't use it.
any tips???the water pump smacks the taurus fan, not near enough room
Thanks for the pictures. I studied them, but couldn't make sense of them. It looks like you cut out like a once inch slot towards the top.
what does that do? How would that allow the radiator to slide backwards by a couple of inches?
