With the big help of my mechanic friends we were able to install the cams. Its a big job, but lets call it a technical job. Using that spring compressor was not easy IMO. You had to get it just right or it wouldnt work. I download the brenspeed rocker tune and the car started up fine, but once it was warmed up the idle was too high 950-1000. Drove around the block a few times and it didnt feel right. Throttle response is slow, actually hidious IMO, idle will drop to 600-750 ish when just coasting( sounds great) but when you hit the brakes to stop it kinda surges to 950-1000 and pushes the car. Decided to drive home and a few miles later the od light started blinking, then two miles later at a stoplight I went to give it gas and the trans acted like it was in neutral. I shifted to first and it moved forward. This also happened again when I stopped again at my neighborhood gate.
Today I did not drive it all all. I just rechecked all connections and for oil leaks. No issues there. I started it up again several times, let it warm up and took another video.
I will call brenspeed tomorrow and talk with Dave. I am very sure this is a tune issue. My trans has never had any issues. If anybody here has these cams and an auto trans I would like to hear from you.
YouTube - 001.AVI
YouTube - 002.AVI
patrick
YouTube - 001.AVI
YouTube - 002.AVI
patrick
You really want to make sure you dont knock any of the followers out of place when placing the cam into place etc... They are barely balanced and knock out of place easily. Another guy on another forum made that mistake and didnt realize to he started it!
