Popping noise in front end?
Ponyup1
Banned
May 27, 2010
217
Adams,MA
Every time I make a sharp left turn to pull into my driveway I hear
a popping noise coming from my front end of my 1996 Ford Mustang GT without applying the brakes.What could be making the pop noise?
Had this same problem, it developed into "pops" or "creaks" when turning on rough roughs, speed bumps, normal turning(body roll) etc, it would even do it with the car off sitting in the garage if I turned the wheel between say 11 and 1 o'clock. I think brought on by my driveway, I have a "bump" type entry, dont have the regular square edge type sidewalks.. its a pretty aggresive bump while turning "sharply" inot the driveway.
I had the car at the dealer 2k before the warranty ended at 76k for it and they did the following:
new tie rods
new sway bar links and bushings
they throughly spray lubed (silicone I think) every joint except the str rack bushings
I got the car back and the noise was pretty much gone, sometimes there will be a slight "pop" which seems to happen most in the morning as im backing out of the garage after the car has settled overnight. I have the poly str rack bushings, just havent put em on yet.. this is where I think the problem is really at, if your car will make the pop noise from turning the wheel while not running have someone do it for you and get under the front of the car, I did and it seemed obvious it was the rack bushings.
There is a tsb for this to replace the str. rack bushings from Ford.
+1 on rack bushings
on mine I removed the bolts (one side at a time) cleaned the holes and the mounting surfaces, sprayed in some lithium grease and the popping is gone
Thanks for your subjestion.
I will know for sure next week when my front end shop diagnoses
the problem.I will let you guys know how it turns out.
