Rotors and pads
jmadams
22
First time post! Thanks in advance for the help.
I have a 94' GT Convertible. Just bought the car last year and its completely stock. Been doing some minor upgrades as I've needed to replace older parts. Inspection is due and it turns out I need new brakes and rotors. Can you guys suggest some rotors and pads?
I'm not looking to brake the bank here just looking for soemthing a little upgraded over stock. Looking for under 100 per rotor, shipped.
Any suggestions?
Ceramic pads generally generate the same amount of dust as semi-metallics. However, they do stop more smoothly, and they don't tear up your rotors as much. Hawk racing pads will make the car stop much better, but they generate a ton of dust.
Kurt
Welcome to the boards!
Personally, ceramics are what I use because they do perform better (than semi's or organics) IMHO and they dust less than semi's [for how I drive].
i use ceramics too, just because.. but be careful with the drilled rotors, some people have bad luck and they crack on them.. slotted or dimpled would be great but its usually a bit more.. if youre skeptical about all the drilled/slotted/dimpled rotors, just go with some brembo blanks..
