actually didnt break anything... i pulled it off last night and nothing wrong with it... just came loose
lucky. You don't run a rev limiter? My 6AL saved my butt many times
i would be willing to bet that the valve came in contact with the pistion if your rocker came off like that, did you roll the pushrods on a flat surface to see if they were bent?
as far as i know it doesnt have one ive sent it into the 7K range twice now. im going to be putting a 6al in this winter. but as far as i know it doesnt have one.
Based on the stock tach or an aftermarket one? Is your engine still EFI?
aftermarket
and yes its an EFI set up
even my factory gauges arent factory... they are the saleen 200mph setup
if you dont have a chip there is no way that the car should have revved to 7000
What is your tach? Autometer?
I've heard ghost stories of a handful of Foxes leaving the factory without a true rev limiter programmed in. Not sure how accurate that is, just something I've heard.
