Factory Ford Forged 4v Crankshaft Question ?
It has to do with the forging dies if they're single plane or two plane.
Some people say "twist forged cranks" are weaker because they are done with a single plane die and to index the crank throws at 90 degrees, the raw forging is twisted to offset the journals in two planes to create the final raw crank blank which is said to create internal stresses in the forging, as well as an poor grain flow in the metal.
Drop forged cranks are done with two plane dies and need no twisting to index, so when the are dies separated it "drop"s out a ready raw crank blank needing no twisting meaning improved grain flow in the steel and no stresses from the twisting.
However the best is billet forged cranks, meaning machined out of a billet of forged steel, way more expensive tho and I don't see Ford sending billet cranks out in factory cars.
So it has to be drop forged or twisted anybody know ?
I was told twist don't respond well to boosted setups, I was about to start my short block and I was going to use the factory crank if I could. If its twist then I'll just order an entire new forged rotating assembly.
The factory Cobra crank is a pretty stout piece easily capable of withstanding a thousand or more HP. And remember, the 2003-04 Cobra was factory "boosted" and responds very well to mammoth twin-screw blowers upping the power to insane levels with no internal reciprocating assembly upgrades at all.
Just how much power are you planning to make? Is this a daily-driver, street/strip, race only or ... engine?
If you're going to be making power that you believe will tax a factory steel forged crank, you're probably going to be looking at every aspect of the rest of the drivetrain, the suspension, the chassis etc too...
I'm hoping to make around 650 crank, 550rwhp with a KB 2.6 . My concern was I would build it for that and then want more power using nitrous or turbo on top and have to take it back apart to put a better crank in it to handle the thousand or so hp.
I have the rest of the drivetrain planned out to handle the upgrades.
Slow on calling Kellogg but I finally did. They are twist to answer the thread, I'm still going to use it with my teksid and forged rods and pistons I'd say the bottom end is gonna pretty much bullet proof. If I don't screw it up putting it all together lol.
