Leaking Oil Without the PCV
clay37355
I seem to be leaking some oil out of the front main seal. I bought a new Race Demon carb. The new carb didn't have the vacuum ports. I drilled the intake and installed a fitting to hook up my modulator for the c4 transmission. I was planning on just running Breathers on the valve covers and no pcv. When I do this though I have the leak. I assume the motor is building up too much crankcase pressure and pushing oil out of the front seal?? Am i going to have to drill another port in the intake? I could use the knockouts on the air cleaner and run the valve cover breather to that, but I am afraid that it will not create enough vacuum to stop the leak. Also, to my thinking, I really would rather not have the contaminated air going down through the carb. Anyone else run into this before? The motor is 351w based 393 stroker.
Bud,
Don't worry about contamination. If your engine was built professionally, you don't have the blow by that creates the contamination. You need to run a VC pcv. This can come in the form of a breather with a built-in PCV, east to find. Buy that carb spacer for the PCV hook up as a minimum. Next from the the driver's side VC portal, add a breather with an inlet and route to the air cleaner. The result will be reducing any "normal" crank case pressures, not to mention reducing oil leak tendencies.
Good Luck!
