Ok, Im sure this has been covered and dont mean to start a new thread but I am reading in circles and not getting a straight answer. A couple weeks back I noticed my 1989 lx 5.0 was starting a little rough. At one point I took the car for a 15min ride shut off, came out of store and I would not start. Turned ignition on and failed to hear pump prime. After cranking car over till batt almost died it finally primed and fired. 1 week goes by with no issues and I jump in my car " no start" , same thing after 5- 10 times finally fires. Im convinced fuel filter is clogged. Put in new fuel filter in and car worked perfect for 1 whole week. Today driving down the highway I felt an abrupt miss as if car just cut out per say. After being parked for 45 min, NO START! NO PRIME! NOTHING! Turns over just fine, reset inertia switch in trunk, swapped out fuel pump relay in parking lot and HAVE plenty of spark. When I turn the ignition to on NO PRIME, but after a few secs hear relay make a click sound .(normal?)
Old and new both make the sound. Dont know where to check next? Pressure regulator? Pump shot? I have also read the ignition module in dist. activates pump also? PLEASE HELP!
Thanks!
Old and new both make the sound. Dont know where to check next? Pressure regulator? Pump shot? I have also read the ignition module in dist. activates pump also? PLEASE HELP!Thanks!
