How much rwhp.. ?
Panhead
I have rebuild my 72 cleveland with these new parts..
Intake. Edelbrock 75641 - Edelbrock Performer RPM Air-Gap Intake Manifolds - Overview - SummitRacing.com
Heads. Edelbrock 61629 - Edelbrock Performer RPM Cylinder Heads - Overview - SummitRacing.com
Cam 32-208-3 - Dual Energy
rockerarms COMP Cams: e=1630-16&Category_Code=UltraProMagnum
Pushrods... Trick Flow Specialties TFS-21408500 - Trick Flow® Chromemoly Pushrods - Overview - SummitRacing.com
ignition MSD Ignition 6200 - MSD 6A CD Ignitions - Overview - SummitRacing.com
MSD Ignition 8202 - MSD Blaster 2 Ignition Coils - Overview - SummitRacing.com
MSD Ignition 8477 - MSD Pro-Billet Street Distributors - Overview - SummitRacing.com
Hedman longtube headders
Edelbrock 1406 - Edelbrock Performer Carburetor
2400 stall converter & 9" with powertrax
All bearing e.t.c. has been changed
How much hp can i espect at the wheels
Thanks.
Sory if my english is bad
Panhead
This is just my estimate, but I would say about 420 flywheel horses and about 335 rear wheel horses. + or - 20 horses. I base this on the info you gave me and you usually lose approx. 20% of your horsepower to the rear wheels.
Thanks alot....:nice:
My car will be tested and tuned in on a Dynapack 4000 at 18 of april
Reime dynatestning.
Will ofcourse be back wit the results...rubhands
By the way....do you use a program to come up with that numbers
Panhead
Panhead
All the programming is in my head, I have built quite a few motors and know what to expect. Also, I forgot to ask what rear gear ratio, but I assumed 3.55 or so. I would love to know the results, just to see how near/far I am.
Sorry...I'll offer a dissenting opinion so that you aren't too disappointed....not a chance of breaking 300 RWHP.
I will not be disapointed what ever the numbers will be....:D
But one thing are sure.... my car are much much faster and much more torque than with my old cleveland with 4v ironheads.:nice:
Panhead
test it on a chassy dyno, estimated horse power is a bunch of bull
Dynapack 4000 is not estimated hp.
Dynapack power measurement can be performed on 2-wheel drive vehicles, or RWD. Dynapacken consists of 2 electro-hydraulic devices are connected directly to thethe vehicle hub . This means that we get on indentifying features wheels that are 99.9% accurate and the problem with wheelspin never occur regardless of power in the engine.
It does not matter if you drive with studded tires or candy, and there are no inaccuracies in the readings due to temprature in the tires, or tires, the car must not be strapped or have x-tra weight in the trunk. We can do a test from my. to max. revs between 3 and 30 seconds, and we can slow the load of all revolutions.
Our dynapack 4000 can withstand load of over 1100 hp on 2-wheel drive vehicles over time, and this is hp at the wheels. The equipment is self calibrating against tempratur and humidity. We warehouses all our tests on the computer and we adjust for wideband lambda. (Censor showing percentage of air and fuel).
This shop even make test at real dragsters
Reime dynatestning.
Panhead
Here is the result of my Dynatestning.
I am very pleased with the results ...
See the difference before and after setting.
And it is true RWHP ..:D
Please don't take this the wrong way, I am not trying to be a jerk, but that's not even 1 hp per 1 ci, ie the ol' milestone of engine building, you can beat that with a high compression 289, so nothing to write home about, more importantly how much did that cost you?
Dude I never said it was, I was replying to robbz28 comment:
"This is just my estimate, but I would say about 420 flywheel horses and about 335 rear wheel horses. + or - 20 horses."
I was somewhat close....10 horses off and just going off of what he had in it...i think with a little tuning on the carb and timing you could get anoter 10 to 15 horses out of it....and 300 to the rear wheels is not bad...you can put that around 375 at the flywheel.
There is not a dyno within 100 miles of where I am, we have to estimate, and are pretty good at it.
